Beaglebone Black with Radio Cape
                    Can I use a Beaglebone black board with the radio Cape. I have a BeagleBone
Black board and was wondering if I could use it and just purchase a radio
board.
board.
If you have a early one might pay to say how much onboard storage it has.
You can of course try installing the software without the Cape.
Make sure you source a good linear supply and don't try to power it through the Beaglebone.
73 Stu
electronics on the board for the HDMI display might cause any RFI problems
even though no display will be connected. The version of my board dose not
have WiFi. I already have a KiwiSDR up and running but do not want to disturb
the setup. I bought the kit from MassDrop a while back. I was watching for another
kit offering but have not seen one for a while. So I thought about just buying the
Kiwi SDR Cape. I do have the Metal case for my second build and have to see if
all of the cut outs for connectors are ok.
Thanks
Mike
N6IMF
I've a Black Wifi (used off Ebay) and it was different to the BBG but fine from memory.
I stopped using it due to frustration with the WiFi connection dropping rather than any EMI issues.
I'm pretty certain many public Kiwi's are based on BBB's.
The only issue I remember was a thin power lead meaning I had issues powering it with just the Kiwi jack, fixed with a proper lead (with some real copper in) and about 5.3V.
Cheers
The enclosure end plate is designed specifically for the BBG and isn't a very good fit for the BBB. You can just leave it off or file/nibble the cutouts.
BBB was used and probably switched to a BBG to save a few dollars. I bought my first KiwiSDR kit on the MassDrop web site. I am
hoping they offer the kit again otherwise I will purchase the radio cape and just use it with me BBB board.
I'm not sure what happened with Drop/Massdrop. It's been over a year since they last offered a drop despite the interest counter on their Kiwi drop page continuing to go up. I can only speculate. Maybe other distributors felt they were being undercut. Maybe it was tariff problems. Who knows..
