Possible bug - static vs DHCP IP address
Hi John,
I've recently been swapping my KiWi IP addresses around and have noticed that when I try to set a static address it doesn't seem to set, unless I set the address, reboot, select DHCP, reboot and then select static again to bring up the previously set IP address and reboot once more.
I don't know if this is a bug or is related to flushing existing routing tables in my network.
  • I changed the KFS system from DHCP to static today and it was not found on the static address until I did a full power off and on at the power supply. Then it came up as advertised.
