What are the chances?
I had some cheap Chinese hair clippers that failed. I tend to recycle as much material as I can so had the lower stainless jaws lying around.
While on Skype my eyes fell on this bit of junk and recognised that the hole size might be close to SMA and be usable for some antenna build, I then spotted that there were actually two holes....
At that point I put my dad on hold and got a Kiwi.
China is metric, most pcb component placement is imperial so the chances of these two holes in a 45mm wide bit of stainless with 5mm corners fitting the Kiwi was close to zero but.
The picture doesn't do it justice.
