Clicking on the AM carrier frequency on SSB
jpejpe
edited March 2019 in Problems Now Fixed
Many times I listen to amplitude-modulated BC stations on either sideband as sometimes the audio quality can be better and you may avoid some QRM. However when you click on a frequency of the BC station in the SSB mode, the frequency will be set at the middle of the passband and not at the carrier frequency. When in the AM mode, clicking on a frequency will set the vertical carrier frequency marker at the mouse point. I think the same behavior would be of benefit also when LSB or USB is used. When listening to ham traffic, then you would click on either edge of the waterfall of the transmission, instead of clicking somewhere in the middle of it to get the best audible signal as you'll have to do today.
Your thoughts/comments?
73 Jari
