sdr.hu API key for an additional RX
I have a kiwi here in Rochester NY as WA2ZKD and have an api key for it. I now need to register WA2ZKD/1 in Rockport, Maine or can I use the same key?
  • You can reuse the key.
  • Related question. I have my own Domain Name and static IP. I'd like to change from rx.jimlill.com to rx.wa2zkd.net Can I do that without having issues?
    edited September 2018
    I'm not sure (I don't run sdr.hu and don't know precisely how it works) The worst that will happen is that you will end up with duplicate entries that you cannot delete. Although this is more classically a problem when you change from using an ip address as your Kiwi's URL to using a proper domain name.
