Lack of coordination?
Tonight noticed a Link 11 signal on top of a designated HFDL frequency.
Also some 3 frequency modem/data link on top of a STANAG signal?
I've also thought that at times the military don't seem to have particularly good frequency co-ordination.
However they do have a fairly comprehensive frequency management systems. NATO has it's Frequency Management Sub-Committee based in Brussels and the UK, Australia, New Zealand, Canada and the USA also has the Combined Communications-Electronics Board (CCEB). Both of these use fairly sophisticated frequency planning tools and maintain frequency databases.
So why do some allocations look so chaotic ?
I think the answer is propagation and the required coverage area. In the 4-5MHz region the required communication is likely to be relatively short distances maybe up to 200km or so. If the wanted signals are strong enough to give adequate S/N in the region they are intended for then everything is OK.
As the intended coverage areas of the transmissions differ, if you try a few other web sdr's in different parts of the world, the chances are that some of the signals you see will be much weaker and others a lot stronger.
So if you are outside the intended coverage area then signals may clash, but inside the intended coverage area hopefully the wanted signals will be dominant.
Ta Dave
