nitroengine
- nitroengine
- 2,245
- 14
Any plans to move to OpenWebRX Plus? [not possible, makes no sense]
OpenWebRX+ has a long ways to go before it's as user friendly and as feature packed as the Kiwi's heavily modified version of OpenWebRX.
OpenWebRX+ is a good option for those who want to set up a remote SDR that can be set to cover frequencies beyond 30MHz and do broadcast FM. That is until a KiwiSDR 3 is released 😉.
WSPR extension (non-autorun) not uploading spots to wsprnet.org [fixed in v1.694]
I was just going to set an Admin password and send you a link, but decided to force an update to v1.688 first.
Guess what? Now the WSPR extension is reporting to wsprnet.org! I'll play around with it and see if it gives any trouble.
I let the non-autorun extension run for a good 20-30 minutes earlier today (on v1.686) and it wasn't reporting at that time, as it hasn't each time I tested it since I started this thread. I let the WSPR autorun go for a couple of days last week and that was reporting as normal.
So far it's working now (on v1.688). My reporter callsign is SWL/EN35.
v1.683
@Yogicat Have a look here: https://forum.kiwisdr.com/index.php?p=/discussion/2444/christmas-kiwi/p1. The logo doesn't get replaced, just overlaid with another image. In my case as shown above, with a pair of Sony headphones. In the past, I've also stuck a set of New Years glasses on the Kiwi as well as that Santa hat.
Just fun stuff. I wouldn't attempt to replace the logo entirely.
If you want to add your own "logo", you could insert a small image in the "Owner info" box under the "Web page" tab using HTML. That will show up in the center of the top bar.
Running v1.678 in 3 channel mode. I'm playing around with the (non-autorun) WSPR extension this evening, and it doesn't appear to be uploading spots to the WSPR database at http://www.wsprnet.org. I've had it going for the past 30 minutes with a good number of decodes shown on the extension. I tested the WSPR autorun, and it does upload spots with that.
