G8JNJ
G8JNJ
4,657
129
  • Direction Finding and linking existing KiwiSDRs
    Take a look at this thread.
    Although it's not available in real time, this may be a step towards it. By processing time stamped off-air recordings and then determining the time difference between each, it may be possible to perform a hyperbolic fix (or similar) on the transmitter location.
    However my maths and coding are not up to the task :-(
    Tonda
  • What is this huge signal?
    Hi Ron,
    It's probably Super Darn. I normally see it around 12MHz but your screen grabs look very similar.
  • Demo of new user interface [now available in v1.154]
    Hi John,
    The LMS "denoiser" and "autonotch" filters work quite well and are a very welcome addition, so thanks for that.
    However I can't open any of the three test sites on my iPad running Chrome. The URL resolves OK but I just get a blank white screen.
    A few other minor observations:-
    The purpose of the 'Slow Dev' button isn't obvious - I think it needs to be called something else
    I'd prefer the 'Slow Dev' waterfall to be white rather than a 'strange' green colour, so that it is a higher contrast display that can be more easily be seen outdoors.
    Should the 'rainbow' spectrum amplitude display bar also be in black and white when the 'Slow Dev' option is enabled.
    The mute button needs to be either on the main pane or the audio panel needs to open by default rather than the waterfall when the browser session opens.
    Why is it WFO rather than WF - what does the 'O' stand for ?
    Should the spectrum display button now be on the WFO pane ?
    If the spectrum display button is moved could a second mute button be added in it's place ?
    Should the green arrow URL button be aligned under the up and down arrow buttons ?
    I'd still prefer the S-Meter scale to be at the top of the control pane
    I still think that the new dBm reading needs to be differentiated from the rest of the S meter scale
    Could the waterfall contrast schemes be better named ? I think they correspond to:-
    • Normal Linear
    • 1. Square law
    • 2. Square law between 21% and 50% spectrum range
    • 3. Square law between 31% and 60% spectrum range
    • 4. Square law between 41% and 70% spectrum range
  • add DTG to Log
    I'd also like to add the KiWi ID to the time and date, so that it makes it easier to use the data at some later date if a centralised database is ever established.
    Covered in these previous threads.
    WA2ZKDKA7U
  • Contact: causes issues [universal browser issue, can't be fixed]
    This is a known issue in the bugs list.
    • Javascript stops on "sendto:" email links. This is a browser problem that may never be fixed according to stackoverflow.com
