I'm not using a proxy but I intermittently have a similar issue when connected via my local LAN. If I connect from a remote site it is less likely to freeze (can run for several hours on a remote connection before I see it freeze but locally it ma…
I may have accidentally stumbled on the cause but not the fix After running my Kiwi extensively on FT8 for the past few days, if I have the audio muted with the speaker gadget, the freezing problem occurs https://forum.kiwisdr.com/uploads/024/KWI2B2…
Thanks for looking into this. I have a fibre connection with 300M+ download speed although I don't think internet speed would be an issue as it happens with my local network connection as well as connecting to remote Kiwis I don't have Firefox but r…
I tried a You Loop with my SDRPlay Duo rather than the Kiwi. It seemed to work reasonably ok on 2m and 70 cm but virtually nothing heard on any of the HF bands and has now been consigned to the jumk pile
Thank you I've returned the height to 25. I wrongly assumed (without thinking about it) that the height setting was my height above sea level. Pretty obvious when you mentioned it The noise is probably a combination of poor aerial (PA0RDT mi…
https://forum.kiwisdr.com/uploads/197/4RHHVT938U5N.png After changing code to that shown in my previous post
This didn't work for me: <iframe scrolling="no" frameborder="0" src="https://voacap.com/geo/kiwisun.cgi?la=-36.8594&lo=174.811" height="100"> Has this been disabled in later firmware updates? Thanks…
Sorry please ignore the above, I have finally found these options in the admin menus
