pistsc
pistsc
22
  • For Cloudflare configuration. You will need to own a domain name and know some Linux command. Instructions: https://developers.cloudflare.com/cloudflare-one/connections/connect-apps/install-and-setup/tunnel-guide The configuration file would be url:…
  • I installed WM BCB filter from RTL-SDR. Things are much better
  • Those 2 BCB stations 1KW during the daytime according to their FCC license. One of the BCB station drop to 60W during the night but not the other 2. I get much better results during the night. I am not sure why since only one station drops their pow…
  • @n6gn I don't have any switch mode power supply nearby. And the audio sound like an AM broadcast.
  • @ArturPL I already lower the gain previously. Mine isn't adjustable. But now at around 4:30pm local time, that AM overload magically "almost" disappeared. I didn't touch my antenna at all. Not sure why.
  • Maybe I have too many WSPR Autorun daemon before? The only difference I could tell is I have reduced WSPR Autorun daemon from 4 to 2
  • Ok. for some magically reason, after my previous post, the HFDL start to decode normally. Don't know what's changed. But it works now.
  • @jks When I use test feature can decode correctly. But it never decodes any actual HFDL transmission. @G8JNJ I did start HFDL decoder from the drop down menu and select a frequency. It won't decode anything. The mode of KiwiSDR when selecting the…
  • I have problems decoding HFDL in KiwiSDR. Simply put, it won't decode anything. However, if I pipe the audio to PC-HFDL application, it decodes happily. Any idea on why?
  • @n6gn So you mean 2 - 3 loop diameters above ground?
  • "Ground Clutter" do you mean it has to be taller than buildings?
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12763#Comment_12763 Got the N4CY loop up and running. Works pretty well. Currently, it's only 5ft off the ground. Does the height affect performance?
  • It would be a great tool if Kiwi could act as a local NTP server
    in Add GPSd Comment by pistsc November 2021
  • @WA2ZKD <200 and prefer off the shelves for circuitry. But if instructions are easy to follow (e.g. TARPN's TNC2), I am open to trying it out.
  • Blue Wave seem nice. Is there any know supplier of similar design in North America? So that I don't have to wait for a few months :)
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12756#Comment_12756 The one from Cross Country Wireless looks very similar to MLA30?
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12749#Comment_12749 So, If I am reading your diagram correctly, this loop consists of 2 coax. At the top where two coax meets. The shield of one coax connect to the center conductor of another…
  • http://forum.kiwisdr.com/index.php?p=/discussion/comment/12748#Comment_12748 This is the article The Airspy Youloop is a freaking brilliant passive loop antenna | The SWLing Post
  • I am using Cloudflare Tunnel. It's free and very fast.
  • Ok. That's good to know. I do have increased noise issue. Maybe this is why
  • mutiband dipole
