linkz
- linkz
- 79
- 6
I've just released v7.20 because of the recent TDoA issues Many thanks to Christoph & dev team for the bug fix in kiwirecorder.py Not much modifications in 7.20, it concerns only the bug: LINUX/MACOS: It will still use an old version of kiwiclie…
Many thanks to Christoph for the kiwirecorder.py bug fix. Thanks to the dev team also Regards &linkz
Yeah I noticed that last night. Both directTDoA & online extension are affected. no recent GPS timestamps on most Kiwis in the octave logs. Thx for the work @BlackForest Question: is there a possibiliy to zoomin to the map? I forgot to answer …
Hi Kai Weird issue, the embedded imwrite (MatLab function) is supposed to correctly save the plot as a .png image. Do you double-click directTDoA.bat to lunch the whole thing ? Else it's probably because you're using your local octave and/or python …
Hi John I'm interested also and I believe some French hams are too :-) 73 &linkz
Hi Ken https://github.com/llinkz/directTDoA/releases download and extract the latest .zip archive on your disk and double-click on directTDoA.bat there is no .exe file &linkz
I've just released v7.00 &linkz
I made some mistakes in the previously released code for Windows. &linkz
A new version has just been published. > directTDoA v6.00 Not much changes for linux and macOS users (just adding back a Listen/Demod service, like in the directKiwi project and some bug corrections) (to get Listen/Demod working w/o re-installin…
@Christoph: I've tried with Octave 4.4.0, still having the same error and crash Wonder why it's not working on that laptop (Win7 SP1 32bits)
(Image) Trying with GNU Octave 4.4.0 to see, but i had problems to install "signal" pkg in the past Ok for your comment, I should launch Octave in a way that it does not read the .rc because it complains on missing files
sorry for those duplicates, something went wrong it seems :'( [fixed -jks]
Hi @Christoph I've just tried the latest repo, now the .cc is compiling OK but still have that same error 81.93.247.141/~linkz/directTDoA/octave4.2.2-win-bug-latest.jpg
On GNU Octave 4.2.1 32bits >> mkoctfile -v read_kiwi_iq_wav.cc read_kiwi_iq_wav.cc: In constructor 'chunk_kiwi::chunk_kiwi()': read_kiwi_iq_wav.cc:63:5: error: static assertion failed: chunk_kiwi has wrong packed size static_assert(sizeof…
Have this >> mkoctfile read_kiwi_iq_wav.cc read_kiwi_iq_wav.cc: In constructor 'chunk_kiwi::chunk_kiwi()': read_kiwi_iq_wav.cc:63:5: error: static assertion failed: chunk_kiwi has wrong packed size static_assert(sizeof(chunk_kiwi) == 8+1…
Christoph At first I want to thank you so much for your work, I was waiting for a long time for the working files from your blog & git and now my HFDF dream came true. Also thanks to John with his KiwiSDR hardware/GPS timestamps in wavs ;) I …
Hi Martin I'm here & I can help you, give me access to your linux box, it will be solved quickly... ;) The directTDoA.py GUI is running fine on Windows, but not the Octave process, everything is ready to work when some Octave.m scripts will …
