kovalr
- kovalr
- 53
- 6
Oh, I didn't notice this option. Thank you so much!
@pistsc hello! I've tried cloudflare tunnels and got an error This page isn’t working ******* redirected you too many times. Try clearing your cookies. ERR_TOO_MANY_REDIRECTS Does you config still work ?
Link to other similar topic "Alternatives to reverse proxy".
Thanks. Fixed.
root@kiwisdr:~/Beagle_SDR_GPS# du 0 d 0 g 0 kiwi 0 n 0 ng 4.0K config.h 4.0K dl 4.0K k 4.0K _LICENSE 4.0K RASPBERRYPI 4.0K types.h 4.0K up 4.0K update_fix 4.0K valgrind.h 8.0K _COPYRIGHT 8.0K kiwi.h 8.0K Makefile.comp.inc 8.0K README.md 12K CROSS_CO…
http://forum.kiwisdr.com/uploads/679/7EDSBGNCSN2J.png Maybe some kind of this
I see. Ok. Thank you. Maybe someone will write converter from .npy to image. I left github issues. This would be a very cool feature.
"Kiwiwfrecorder (note not kiwirecorder) is a specialty program Christoph wrote that saves waterfall data together with GPS timestamps as Python Numpy array format file (.npy) which with some code changes could probably be an image file as well.…
Hm, it also make sense.
Thank you! We have succesfully installed your extention and it works. In our case we have home made switch builded by following shem: (Image) With 3 relay we could switching between 4 antenas. If we want to use antena #4, we need to send hight …
Hello, I want to install this extension and use beagle-gpio. But some questions appear: 1. What gpio port should I used ? P8 11 - GPIO 1_13 P8 12 - GPIO 1_12 P8 13 - GPIO 0_23 P8 14 - GPIO 0_26 P8 15 - GPIO 1_15 P8 16 - GPIO 1_14 P8 17 - GPIO 0_27…
Simple data visualisation from my KiwiSDR receiverGoogle data
Hello! Yes, I've checked already. It works! Thank you so much!
Hello!Can we expect this feature soon? Here is explanation in graphic way. Thank you in advance
Thank you for information.
User generated java script code from his own google analytics web panel. Something like this: <script>(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]||function(){(i[r].q=i[r].q||[]).push(arguments)},i[r].l=1*new Date();a=s.cre…
Thank you!
noip.com service in free account asked to confirm host name every 30 days. I've found another similar service which is doing the same but without noisy confirmation.https://www.dynu.com/ Is it possible to add this service for DDNS please?
