johnk5mo
- johnk5mo
- 161
- 1
By "same" I mean both values seem to be the same. The number of course varies throughout the day.
I agree with you Kovalr...this would be super handy
I'm sure you're right. The politics that has to be endured to continue to enjoy the relative free reign of such a facility has to be monumental --- particularly where they are. Fortunately the quad is running again.
One of my ball bearing fans (installed on May 1--see above) got noisy and was failing . Peeling back the label and putting some thin synthetic lubricant has made it like new at least for the time being (thank you Ron!) While I was at it, I decided …
Where are those pesky parenthesis when you need them?
Thanks John! Take the rest of the day off :-)
By the way this happens here a LOT if I don't have the BCB filter inline. It's nothing special, a "bare bones" labeled unit from EBAY for $9USD . It makes all the difference in the world . Without it the Kiwi is completely saturated with…
Same here Chris. Mine run outside thru 3" PVC pipe to the tower, but are grounded when they come to the surface (and that ground connected to my service entrance ground). It's the best I can do.
Got it. I use a homebrew 4 port active distribution amp for my multi Kiwi setup. You should just be able to clone the setup (through your admin page access) of your 2nd kiwi exactly the same as your first, and just define the 2nd radio to a differe…
Yup...Occam and his razor are still a "thing". I found another industrial power supply in my stash (open frame linear) that's 6A at 5 that I let cook for a day loaded at 2A and it's been fine. I'll swap it out and move on to my next deba…
OK ... life gets in the way and the Kiwis sat for a couple weeks, and time to bare my soul again and share that indeed it was power supply issues again. This has been a strange journey made stranger by several problems that were all of the same typ…
Is the first step to get two independent Kiwis on line and receiving?
Those of us with shacks on the second floor have to make do! :-)
Linear chargers rock! Excellent catch.... and good on your neighbor to work with you.
