:-) w/c //Dietmar
Tnx Kiwi is back - tomorrow I will bring it back into the shed. Hope you can fix it with the next release!
Sri but I don't get the point, how to display the admin panel: http://192.168.2.77:8073/admin <- did not work as you explained http://192.168.2.77/admin <-- is blocked by HTTP 403
Thanks for your feedback! I've tried this also before http://192.168.2.77:8073/admin I still get ERR_CONNECTION_REFUSED. If I'm correct there are no listen ports on tcp:80 or tcp:8073 open?! root@kiwisdr:~/Beagle_SDR_GPS# netstat -t tcp -a Active …
Here the desired info: Mar 4 17:40:38 kiwisdr kiwid: 00:00:00.046 KiwiSDR v1.493 -------------------------------------------------------------------- Mar 4 17:40:38 kiwisdr kiwid: 00:00:00.050 compiled: Mar 4 2022 12:33:05 on kiwisdr Mar 4 17:40:…
Tnx lets see how the 1.370 update runs ...
Good hint but even after cache clean it says 1.364 ... Where can I check the update result? Logfile?
No - didn't help
So here the data: -------------------- root@kiwisdr:~# scs avahi-daemon ? avahi-daemon.service - Avahi mDNS/DNS-SD Stack Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled) Active: active (running) since Sat 2018-05-19 09:47:41…
Ping never works in command line with a full installation of the latest iTunes. Removing Bonjour didn't solve the problem.
@JKS Microsoft Windows [Version 10.0.17134.48] Yes rebooting was done several times in the meantime @JohnT What is the ITunes fix? BTW - sorry for using a niche operating system :-/
You're right, there is an error: ? kiwi_util.js:459 getVarFromString: NO SCOPE cfg.ant_switch.denymixing scope_name=ant_switch kiwi_util.js:51 Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safa…
Hi Mauritz this option I missed - but in between Kari also fixed his code. Thanks for the hint. //Dietmar
Hi MauritzHi Martin I experience the problem, that the antenna switch extension is not working after a restart of the Kiwisdr server.You can click the buttons in the WebUI but nothing happens at the frontend and backend! I always have to restart th…
Hi Forum I found one issue with this extension. After restart of the Kiwi server (for example after FW update) the extension isn't working. You have to reboot the beagle bone to get it working. Has anybody also discovered this problem? Has someone a…
Is there a simple way to define the default antenna, that is selected, after the KiwiSDR has booted? Not every remote user knows, that he has to select an antenna if he doesn't receive anything ... //Dietmar
I'm running this "Bel Power Solution HAA512-AG".Enough power for the KiwiSDR and additional power for an active loop amplifier.Its open frame same as the Kiwi - but you know what you get.
This is a good hint - thanks! So the way to a page on the web admin ... //Dietmar
Hi Martin thanks for the detailed reply - I first have to understand it ;-) then I'll come back to you ... //Dietmar
Ah - great explanation - thanks! Forgot the GPS sync during all receivers idle - now the picture is clear.
Great - I'll do this immediately! //Dietmar
Better would be without any active session - real background mode
Hi JKS thanks for this quick analysis - I've disabled it - let's see //Dietmar
