https://forum.kiwisdr.com/index.php?p=/discussion/comment/13658#Comment_13658 I am doing update_fix on two remote Kiwi's -- I'll keep you posted...
After 4 or 5 times... after an hour or so I end up with a line like this -- and many more before it... and nothing more... clang++-6.0 -Dv1_506 -Ofast @../build/gen/Makefile.inc -std=gnu++11 -c -o ../build/obj_keep/DRMReceiver.o extensions/DRM/drea…
Now at over 90 minutes listening on the oddly behaved Kiwi --and I will bet, without fail, that if I logoff the Kiwi and come back 10 minutes from now, it will have "gone to sleep..." - Could this possibly be a bad ethernet port that is go…
http://forum.kiwisdr.com/index.php?p=/discussion/comment/12132#Comment_12132 Yes - it does have a GPS antenna with good acquisition -
Separate PS units -- running a custom 5A - 5V supply (LINEAR - BEL PS) that I have used at home shack for several years -- the one "on Island" is in an aluminum case with (we think) plenty of air flow -- so, yes it is suspect until all oth…
So - what I think I am hearing here is -- Yes, heat can cause a Kiwi to shut down.. Is that an accurate statement? Good to know! Thank you.
I took a look at that forum post and I must be daft - I see no explanation of how it's done -- apart from an explanation that is started in the middle of DX Labeling or something -- Maybe someone could issue a post or link to where this is all descr…
I am seeing this as well -- relentless Asian IP's dropping on 10054 khz USB over and over again - kick them, they reappear minutes later -- is this a BOT or a Human or a port scanner or? Would someone post their BLOCK IP list and I will add this to…
Update - NOT all DC Plugs are the same -- I found one with slightly different dimensions - and it works 100% now - Can anyone reveal the EXACT DC Plug that should be used?
Please toss me a schematic for a single frequency notch at 1070 Khz -- Many thanks!
Just joining the show here -- but what is SAM? Many thanks - Colin - VA7WWV WebSDR KIWI - Victoria B.C. Canada kiwiwebsdr.dxer.ca
I'm quite happy with my CLONE of the Wellgood - I use it up against an ALA100LN and the Wellgood is a couple of db hotter but also 1 - 3 db noisier... run it at 12 VDC -- I run a couple of IMD tests on the unit when I am setting it up... Great for a…
I built a simple 15 db 50 ohm pad for the antenna line in -- fixed all of my overload problems - 3 resistors! 2 BNC female jacks.
Very helpful stuff! I think my smartest option is to get a wireless extension unit - like this one TL-WR802N - (as described above...) https://tinyurl.com/kiwi-websdr-bridge As described above and not mess with the BeagleBone install...
My new KiWi Websdr works like a charm - the only downside: My WiFi router is located on the 2nd floor of my house and the radio shack is in the basement 2 floors down -- and no ethernet cable between them. Question: Can one run a WiFi dongle off of…
You are correct! And while re-doing my rewind of T1 I realized my mistake: I put the singles on 1-7 and 2-6 as opposed to the instructions of 1-6, 2-7! My Bad. Fixed that and initial tests are good. I would like to do single tone IMD with an LPF/HPF…
Got one of the boards - assembled it using the exact parts as listed. Unit did not work on initial power up. Comparing Dr. Smarts schematic to his Toroid winding drawings revealed a glaring Error - note attached photos. (Image) (Image) Geor…
