alain_
- alain_
- 102
- 5
Just for posterity: I had the exact same issue describe in this thread, solved the same way. I hope pins aren't getting loose!
Thanks for the very useful feedback. I suspected the "ramp up" time since the beginning and now my suspicions are even higher. Unfortunately I don't have a scope at this location, but I already ordered a delayed relay.
It would be nice if those labels could somehow be dynamically refreshed, crowd sourced and customized by geographical area
I will stick to the 5V because the circuitry internal to the battery would increase safety and also provide charging circuitry. In order for my discharging capacitor to do the job, I will try adding a the right combination of diodes (zener) on the r…
on a second thought, that capacitor cannot work with the relay. :(
My goal is a solution able to avoid short power interruptions under domestic circumstances and I agree that the UPS solution (although easier) seems unnecessarily expensive and potentially noisy. One idea I am exploring is to use something like thi…
I have seen many devices like that battery but I am afraid they would all be switching. Wouldn't they?
Rob, Yes I noticed the effort to have the daemon run on Macs. Yet, I thought that running it with a single command and without installing anything was a nice thing to have. I didn't want to publish my own image but if I had anyone could have run yo…
My tunnel does not present two different public ip addresses. Besides, I have my good reasons for using my own proxy and I prefer not to use the one provided by Kiwi (nor to publish a household IP address to the world). I can live without sdr.hu, n…
I wonder if a filter could be built for this specific type of problem...
The beaglebone creates an ssh tunnel to an host in the middle and forwards a remote port to port 22. I then connect to the middle host on that port. I have used the same setup for years with a Rapberry PI, never had any issues with it
I'd like to point out that setting the eth card to 10-base-T made a huge difference in terms of noise. Thanks Ron for letting me know. I also would like to point out that living in NYC is probably one the worst spots in the world in terms of noise, …
It could be filesystem/eMMC damage, in my opinion. I was thinking the same. For now I am restarting kiwid twice per day (I really cannot afford sshd to go down on me as this is a remote setup!)
Thanks great info. Thanks!
Martin, Thank you very much for your suggestion. I might try to build one on SMD directly with male-female SMA connectors. Alain
That could be the explanation... :/ Thank you
Ron, Thank you for the promt reply. Holy cow, your setup puts mine to shame!... Unfortunately I cannot put my hands on my receiver as it is located in Europe while I am in the US. I will however definitely try to set 10 base on the eth card. Alain
Ron, I believe there were no updates. If the eth cable was the cause I wouldn't have been able to login via sshd. But I have... Alain
I forgot to mention that I use the Chinese Linear Power supply suggested in the KiwiSDR documentation. The board is not enclosed
I just finished installing a 1.2 meter copper loop with a commercial LZ1AQ amplifier. The station is in Central Italy. The overload indicator was up all the time so I temporarily installed a 15dB attenuator (by Mini-Circuits). The indicator is now …
The problem seems to be my 32GB micro SD. Worked fine with a 4GB card. I guess I have all the answers to my questions now... Thanks anyways!
I guess its backing up the whole thing. The problem now is I'm getting this:ADMIN: received microSD_write-----------------------------KiwiSDR: copy eMMC image to micro-SD cardVersion: [1.20151007: gpt partitions with raw boot...]--------------------…
The new clone solved the issue. Case closed. Thanks!
I see a lot of empty files... I believe that is not right:root@kiwisdr:~/Beagle_SDR_GPS# ls -latotal 92Kdrwxr-xr-x 17 501 staff 4.0K Aug 10 2016 .drwx------ 5 root root 4.0K Aug 10 2016 ..drwxr-xr-x 3 501 staff 4.0K Aug 10 2016 arch-rw-r--r-…
The commands provided shows nothing in particular:root@kiwisdr:~# cdproot@kiwisdr:~/Beagle_SDR_GPS# mdimake: *** No rule to make target 'disable'. Stop.root@kiwisdr:~/Beagle_SDR_GPS# mstmake: *** No rule to make target 'stop'. Stop.root@kiwisdr:~/…
