John, I followed your advice, downloaded the latest software, unzipped and wrote the new image to the SD card. It appears as if the SD card that came with the KiwiSDR was blank, no wonder it did not update the firmware. Fortunately, everything see…
I separated the KiwiSDR from the BeagleBone Green, inserted the SD card and powered the Beagle with the RPI power supply. Some of the LEDs flash, but it does not get to the point where the LEDs run left to right and vs versa. I did this with and wit…
John, Thanks a million for the advice, I will do as you suggested. I have read the KiwiSDR can be removed from the Beagle during the re-flashing? I can power it with a Raspberry Pi 3 power supply? I suspect the data on the SD card is also corrupt …
