Ulli
- Ulli
- 15
- 5
Hi, IP-adres 130.211.233.123 constantly bombs my SDR3 so finally the kiwi became unavailable to the public... I have added 130.211.233.123/32 to the blacklist... hopefully it helps... Ulli, ON5KQ P.S.: All kiwis are fully available to the public (4…
There indeed something happened to my router, which prevents NAT loopback to work as usual. There was just no indication what the reason for that malfunction was... So finally I reset the router to Factory settings and build the whole configuration …
Thank you for answering my question.... Tablet is connected to Ethernet 1 - LAN poort Kiwi's are connected to Ethernet 2 - LAN poort Ethernet 0 - is WAN poort Then I forwarded poort 8073... 78 only on Ethernet 2 In the past I could surf from Tablet …
Thanks for the quick update, John 73s and merry x-mas! Ulli, ON5KQ
My un attended kiwis were hit yesterday from 10h utc... Unfortunately I didn't find our until this morning Needed to reset router as well and also the setting of network switch to establish the general Internet connection. I guess, because I realize…
not correct - please try again. The Address is correct I had reset the interfaces at the router site - so for a very short moment (max 10min) the adress was wrong as you state - but not any more... Fact is, that since the update from vers1.461 was t…
Now - I have written a new Sandisk Ultra SD-card with Vers 1.464 to flash directly It works with the first kiwi, with the second kiwi - the third kiwi breaks with 'this site cannot be reached' error - all other kiwis are always off... only one kiwi …
Connecting my IP-adres directly with 213.118.213.254:8074 indeed reaches the kiwi correctly ! So this shows, there is a problem with noip.com! I should better use a different service then...they may have changed something, which breaks the proper dy…
on5kq.ddns.net:8074 can never be reached - I checked with GSM via Phone Network But kiwi shows that this port is open, if you connect to my IP-adress under that port - obviously, because I route all requests of that outside port to the inside port o…
"...I have used the noip DUC, they offer to download for windows and used it to confirm the service works." It doesn't matter - from the same network or from outside... "...I get 213.118.213.254 is that correct?" Yes it is correc…
Tried once more early sunday morning: start kiwi with newly written flash card, vers 1.390 after kiwi switched off, take out flash card and restart kiwi - as soon as kiwi web-admin (showing vers 1.390) switch off automatic update in vers. 1.390 go t…
The reason is, that I want to see the response of the update_fix in the console, to see possible errors - I can't see that when doing automatic updates...
upgrade is not ready yet... just saw this fault after the first minutes of upgrade 1.390 --> 1.464
I see now different faults: for example clang++-6.0 -Dv1_464 -Ofast @../build/gen/Makefile.inc -c -o ../build/obj_O3/fsk.o extensions/fsk/fsk.cpp /bin/sh: 1: cannot open ../build/obj_O3/fsk.d.tmp: No such file That did not happen before!
I am rebuilding the kiwi-OS again from flash-card. I use the console with update_fix command now - need to wait almost 90min to see, if the strange file-system errors appear again... Will let you know...
"this site can't be reached'.... white background... nothing else
John, "...First, do you get just a white/blank screen or a browser "can't connect" error?" Yes, exactly - connectivity breaks - so I need to rebuild everything to input anything you suggest. But it is already almost midnight - it…
I'm sorry - back to where I have been yesterday: 1;) upgrade from clean kiwi-OS from flashcard 1.390 (dropbox file) to 1.464 at the end from the process, I can see vers 1.464 in the web-admin page but for example still with original QTH grids, etc.…
John, can't you offer Vers 1.461 somewhere for download ? For the moment new features are less important, as with 1.464 any reboot keeps breaking all connections to my kiwi's anyway. But Vers 1.461 worked....
And because I have strong passwords on all my kiwis - updating from Vers 1.461 to Vers 1.464 breaks the connection of all kiwis after reboot immediately. It has nothing to do whether the update has been done in the console with 'update_fix' nor auto…
John, whole day busy with the kiwis... I found the following: There seem to be a connection problem with the DUC in the kiwi-Software for the noip.com Dynamic DNS Service! Remember that I tried to update directly from 1.461 to 1.464 (which includes …
John, I have seen that, but didn't focus on that issue (yet)... I can try to take a different SD-card to flash... (weekend)
I attach the text file, which contains the complete upgrade response from the Kiwi-SDR console tab when doing 'update_fix' from the latest dropbox flashed SD card file (kiwi OS Vers 1.390) http://forum.kiwisdr.com/uploads/575/LO8AAIT09S44.txt It is …
"...perhaps you can't ssh simply as it is too busy?" hmm, seems unlikely to me, as I so far tried SSH only after upgrade script has finished and after reboot. That was the moment, when after reboot the kiwi-webpages disappeared and the bro…
John, good morning! Don't worry - it is more valuable for me to understand what is the reason for the problem - so the effort I have to put into that MYSELF, is not for nothing. I am sure you would be able to help me within minutes in reality - howe…
"...so that future connection attempts will work without the need to ask for permission again." My point is, that they don't work after all what you described (and what is already mentioned in the SSH alert) No SSH No admin page of the kiw…
My Point is, if I input, what the message says and try to ssh again - no way to log in. Similar message - just the 'offender' randomly changes... Obviously the ssh password is not 'understood'.... I will start rebuilding the kiwi OS once more (5th t…
John, Similiar than others, I find the update process (update_fix in console) doesn't work. My first attempt with just one kiwiSDR for initial try, results in no connection to admin window no SSH connection possible any more etc.. etc.. I then made …
Hi Rob. This morning when I restarted WD, the new version 2.8a installed from github... At the end of the progress report of the installation I get 2 lines of "warning" : The directory '/home/on5kq/.cache/pip/http' or its parent director…
Many thanks for your great work, Rob. My problem is, that I often do not understand the meaning of any errors, which might occur, as I am a real beginner in Linux... however the Internet helps... but it takes looooooong time..hi Side-effect: I keep…
