GaryG
GaryG
333
2
  • I think it's an improvement, the "option tab" for selection does simplify the look and does unclutter the screen. I did notice that it took two 'return' presses with Edge browser to switch frequencies; using the Brave browser it was only …
  • Hi Windows 10 Pro - set to approximately the same frequencies and zoom levels as your picture, no problem. Only differences, Windows Edge as the browser and nowhere as many tags as you have showing, could that be a problem? GaryG in Vancouver, BC
  • sep_store has lots of linear supplies listed, could you mention which one(s) you purchased please. Thanks, GaryG
  • Hi John and others, Simple question - When removing an SD card, is it safe to do it with power on? I realize inserting the SD card must be with power on otherwise the system would try to boot from the SD. Gary in Vancouver, BC
  • Hi I see the same as Dave with the exception that very occasionally I do see a RSSI bar for a short period (seconds). The antenna is facing toward the sky with approximately a 10 degree by 70 degree opening  although through double glazed glass. For…
  • If your Router supports MAC address to IP address assignment you then have an IP address that never changes or, in effect, a static IP address.  That's what I did here. For those who may not know how to find its MAC address, the Admin access, Networ…
  • Hello all, my first comment at this forum. I received my KiwiSDR Kit a few days ago. I am using the kit's GPS black blob at a window with limited sky view. I was seeing very poor results. After noticing the magnetic base, I had a thought; "Doe…
