F5LFE
- F5LFE
- 99
- 5
I received the replacement protection today, plugged in and the kiwi looks like happy ;o)) There is no noticeable attenuation with this one. Thanks again for the way you managed this issue. VY 73 Francis.
Today I tried something else. Since the power plug of the kiwi is a 2 contacts (phase and neutral) I reversed the way it is plugged into the socket. The effect of the groung connection on the SNR mesurement has been changed in the other way around.
Hi, No lightning strike yet. I did not receive my protection it will be in a couple of day. But since I am working on the ground matter better to do everything well in once.
do the kiwi and/or the antenna need to be grounded to have this protection working efficiently ?
Tnx for your comments I will try something in this way. I found a temporarily solution which I would assess as a dirty workaround but leaves me the possibility to stay in the top ranking. I grounded the kiwi through my kmtronic realy board and sele…
From a SWL point of view you are right the HF signals are the most important. But from a ranking point of view when you filter the Kiwi list to view only the french ones I loose quite a lot of places. So if I could fix this I would be happy. If not …
any idea to fix this ?
https://forum.kiwisdr.com/uploads/906/DF690YMDCOOL.png
Tnx for the tip. When I connect the ground I loose around 20 dB between 500KHz and 1300 KHz.
Ran the test, nothing wrong 73 F5LFE
I would bet on the postal process since the envelope was not in very good state
Hi, the meaning of "two different adaptators" is the way to connect the PCB female SMA to the kiwi female SMA
Many thanks in advance. 73 F5LFE
Tough luck to me... on the top of that it took 6 weeks to come home. I am going to order another one then. 73 F5LFE
Thanks for your hard work to the benefit of the community
59 +30 db without the protection and 53 with the protection The frequency is 162 KHz
I did not set the RF attenuator correctly so I did it and restarting the server fixed both problems. Many thanks for your help. VY 73 F5LFE
Additional info : the time limit exemption does work but not the attenuator nor the antenna switch
Nice features but... I cannot use the cmd+C with my MAC anymore for copying text. Instead of copying it goes to the control tab
Thanks to both of you. I am going to purchase a 32 GB MicroSDHC. VY 73
This is done, you can connect to it for testing mixing antennas. A picture of how I did the hardware : https://forum.kiwisdr.com/uploads/705/M7AW00DW4ESJ.jpg
My pleasure 😊 Thanks to you for helping so quickly. I noticed they are not a lot of Kiwi 2 in France and even less with the switching feature "on" Next step, the connection of the antennas I am very curious to see the result of mixing up …
Hi, which nc doest not return anything https://forum.kiwisdr.com/uploads/177/2QGH8GYGQD8I.png after manual install : https://forum.kiwisdr.com/uploads/467/RRQPC85WKUKY.png And now it works 😋 That means that somewhere an update needs to be done with…
When I clic on the Thunderstorm mode button "yes" and after "no", the log reports the same command (as far as I understand well the log) https://forum.kiwisdr.com/uploads/071/YQS1YFDK7MV7.png
Thanks for the explanations. I received the 8 channels version. So far I just connect it to the LAN, no physical connection to the KiwiSDR and... I opened a discussion in the "Problems and issues" category
Even that the switch ip is the default one I created the configuration file in the /etc/default folder Still the same problem
a bit more information : https://forum.kiwisdr.com/uploads/471/N2UTPG8U5BSA.png
Added info : my transmitting power is 100 watts
My antennas are not far away from each other (around 15 meters). I installed this equipment on the Kiwi Rf in : https://fr.aliexpress.com/item/1005004883750098.html?src=google&src=google&albch=shopping&acnt=248-630-5778&isdl=y&sl…
