OK, thanks, off there now.
How can I split the output from one Leo Bodnar to several Kiwi SDR's please? For 10MHz I use a commercial 75 Ohm box, not sure what's best to use for 66MHz? Thanks.
Thanks, those are the ones, I got a few thinking to use one for my Pluto SDR, again for an external GPS locked LO. I ended up doing the direct coax connection as on my Kiwi as a U.FL wouldn't really fit the pads left on removing the tcxo.
My bad, on looking at what the bit of debris in the photo was that I had left by the crystal oscillator I noticed the xtal frequency was not 66.66 MHz but 66.666 Mhz, so corrected the pen marking ;) The debris was just a bit of flux residue from whe…
Thanks again, I have managed to solder a miniature Teflon co-ax to the pads, and place an SMA socket in the front panel, I appreciate your advice and PM's. https://forum.kiwisdr.com/uploads/957/E1V2OP1O3A9R.jpg https://forum.kiwisdr.com/uploads/930/…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13246#Comment_13246 Ah OK, so you can disable the stock oscillator by software, that's very good, thanks I hadn't noticed that option.
Thanks, I admit I failed to find that discussion, however, I don't see any photo in the antenna switch discussion I managed to find showing the pad to connect the external oscillator to. Also, do I need to somehow disable the internal oscillator whe…
OK, thanks, I will take a look there later, much appreciated.
Thanks Rob, all working nicely now.
Thanks, for some reason ssh and VNC were no longer set active, so I fixed that and hopefully it I have now updated wsprdaemon, but it no longer seems to auto start the wsprdaemon on reboot. I have to manually start it in the terminal Sorry to be a …
OK, thanks, I see I misunderstood the title in either case, my fault! I did re cycle the Pi and still can't access it remotely, I'll pull it out of its hiding place and put a monitor and keyboard on it. Should re cycling it have purged the logs if t…
Is this not a typo on the github site? "Installation on a system with an existing copy of wsprdaemon not installed using 'git clone'" These instructions are for a system WITH wsprdaemon installed, surely? I have an earlier version of w…
Thanks Martin. I decided to click again on auto add NAT and reboot the Kiwi again. This time it came up with a message that it had now added NAT to the router settings and the ports are once again open! Not sure why this changed, but hey, with netwo…
OK, just seen these last 2 posts, thanks very much. Rather than start a pretty closely associated new thread I'll try adding my question here. I would like to be able to modify settings in the WDconf file remotely, with no local screen or keyboard c…
Thank you, renaming the "extra" one in /tools seems to have fixed this anomaly, many thanks for the reply. If it behaves for a couple of days I'll just delete it.
Thanks rrobinet, your reply is all I need to know, I'll write the RP image and be patient, thanks for your work on this great addition!
Can an RP card be pre prepared without an actual Raspberyy Pi, I have a Pi 3+ on the way, thanks?
