M0TAZ
- M0TAZ
- 219
- 20
Tell us about your station!
OK guess that's me next then.Location residential, suburb of London UKAntenna - Wellbrook Loop @6mOverload from MW stations around 25 miles away, mitigated by rotating the active loop.Linear power supply picked up from a rallyFerrite cores placed on anything I can find50 Meg fiber connection.Need to place KiwiSDR in a metal boxIssues to resolve, noise floor raised around 3.5 MHzIntermittent SMPS noise (not in my property)Intermittent noise (local railway)Performance seems quite good but local noise is limiting factor on some freq.Works quite well on 472KHz WSPRwww.m0taz.co.uk -
Active antenna supply ?
You may find this interesting -
Suggestion and comments on GPS please [resolved, see list of improvements]
OK, an update for the group. The GPS issue is mainly fixed now, these are the steps I needed.
1/ Remove GPS patch from the puck, replace coax with something double screened.
2/ Attached the braid and shield of the puck can to a metal plate 40 x 40 cm
3/ Elevated this in the air to provide some clearance for house/trees/fences/local clutter
Each time I did one of the above it got better, and I hope its now mostly fixed. -
I was so happy with the puk on a metal plate I decided to pick up a decent GPS antenna from ebay. HUBER+SUHNER 1315.17.0008 1575MHz 34dB N female gps antenna antenne Aerial (ebay search terms)
This is now coupled to a short length (circa 6m) of LMR400. That really is the best I can do now, short of re-locating the antenna on the roof. The GPS antenna was £15 delivered from China, and it would seem to be the real deal. -
GPS fixes diminish [fixed in v1.218]
