34,850
551
  • Seeed KiwiSDR metal enclosure finally available!
    FWIW, Mouser USA is currently showing 4 enclosures in stock. I don't recall seeing this before. Shipping will be faster and less expensive than buying from Seeed for those of you in the USA: http://www.mouser.com/Search/Refine.aspx?Keyword=kiwisdr
    KK6PR
  • periodic drop-out with ver. 1.240 ? [fixed in v1.241]
    There was a change made in v1.240 that fixes one problem for the guys making >= 6 kiwiclient connections for use with the external WSPR processing script. But it involved making a "risky" change to the task priority of the internal web server of the Kiwi. I was very worried this might cause problems with the real-time response of the audio tasks. And, despite all my testing, this now seems to be the case.
    So I'll revert that change in today's update and hopefully that will fix it. We'll have to find some other solution for the WSPR guys.
    G0LUJ
  • raw I/Q channels
    When you mentioned "external decoders" I assumed you were interested in I/Q obtained from the L/R channels of the browser audio output, e.g. so the browser could be used to control the Kiwi. It is indeed possible to connect over the network (via web sockets) to the Kiwi server and issue the same API commands as the browser UI does to set frequency etc.
    An example written in Python that works on Linux/OS X is called kiwiclient/kiwirecorder available here: https://github.com/jks-prv/kiwiclient/tree/jks-v0.1 It is capable of recording to .wav files but there is no reason you couldn't stream to another application. I think Christoph was working on (or has working) an interface to GNUradio this way. The I/Q mode bandwidth is of course limited to the audio channel bandwidth (currently 12 kHz).
    ChrisSmolinskiKA7U
  • v1.239: shortcut keys 'x' & 'y' for UI visibility control
    No time soon. I have to do something about mobile. It's intolerable. And Daniel has been rightfully taking me to task, viz:
    However, the current client has more obstacles to mobile friendliness than just the UI. For example, it sends nearly a megabyte of non-minified, non-gzipped JavaScript on page load, and the server even intentionally disables the cache for mobile clients.
    Press 'x' to quickly toggle the visibility of all control panels.
    Press 'y' to toggle the top bar and band/tag bars as follows: both visible, one visible, the other visible, none visible. The frequency scale remains always visible.
    Mobile-device equivalents of this, and mobile improvements in general, are being thought about.
    PowernumptyG0LUJG8JNJic8pof
  • raw I/Q channels
    ChrisSmolinskiKA7U
  • Strange Log entry - any valid reason for this?
    I see those occasionally and don't quite understand them. But I also haven't spent any time trying to track them down. My guess would be some buffering problem where a configuration save command from a prior admin session is leftover someplace and gets flushed out to the Kiwi during the next connection (the arrival from China in this case). I don't believe anything malicious is going on here.
  • Save money on another Kiwi or tell a friend [KiwiSDR sometimes on drop.com for $100 off MSRP]
    October 7/8: Massdrop is active again for 7 days. $80 discount on the Kiwi kit ($219 vs $299). Free (but slow) shipping to the USA. Best deal out there. Limited quantities available and over 70 people were on the notification list. So don't delay.
    rrobinet
