My KiwiSDR is no longer showing up on map or lists.
In the last few days my Kiwi is no longer appearing on any maps or lists. When I go to the admin/NETWORK tab and use "Check port open" I get NO for both checks.
I am using ddns.net and have set my address, wa6our.ddns.net, in the CONNECT tab. When I try to connect using http://wa6our.ddns.net:8073 it works fine.
My KiwiSDR is at V1.390. Not sure why it has dropped off of the lists and maps.
Jim Gay
wa6our
Jim Gay
wa6our
Jim Gay
wa6our
Jim Gay
wa6our
Distracting Junk removed as I was on the wrong track
The other possibility is that your ISP is blocking it with a new firewall (Comcast I think has been a recent one for doing that)
Ah I see you may be on Comcast from the ping IP, I will return with the link...
73 Stu
"For future reference for we American types, here are the Comcast/Xfinity menu selections to allow a KiwiSDR through their system.
5. Exit.
This info accurate as of 02 April 2020.
JIm
wa6our
Thanks for your help and ideas.
Jim
wa6our
