rx.kiwisdr.com now has a search field
For what it's worth, rx.kiwisdr.com (aka kiwisdr.com/public) now has a search field where you can search/filter entries from the list.
Same thing as sdr.hu has (and the last reason I was using sdr.hu). Matches are case-insensitive. Clear the search field to restore all entries.
Good for things like searching for Kiwi's on a particular release ("v1.389") or with a particular feature ("drm", "20 kHz", "gps") or location.
kiwisdr.com registration status:kiwisdr.com/public registration: successful
What to do in this case?
ua3ahm.ddns.net
admin@radial.ru
Has port 8073 been opened on your router and directed to the Kiwi so that incoming connections from the Internet will be received by the Kiwi? Is your Internet provider a cellphone company, or other, that might be blocking incoming connections? If the later we might have to use the Kiwi proxy service to bypass the blocking.
Now http://ua3ahm.ddns.net:8073/status available.
Thx
p.s. Nice antenna, WOW! It has great VLF/LF reception too. It is hearing NWC Australia, 19.8 kHz which is pretty astonishing.
There is now a checkbox that says "open in a new tab" i.e. for when a link to a Kiwi is clicked. The checkbox value is saved in a cookie and restored on your next visit. It defaults to "checked/yes" and can also be overridden to "unchecked/no" by including the URL parameter "notab".
