v1.387, 388, 389
From the CHANGE_LOG file:
v1.387 April 10, 2020
Admin page control tab:
By special request, added ability to limit number of simultaneous non-Kiwi API connections
(e.g. kiwirecorder). This works in the same way (and overrides) the TDoA extension
setting that limits the number of simultaneous TDoA connections.
DX label edit:
Passband frequencies can be entered using "k" and "M" suffixes for kHz and MHz.
I.e. "2100" and "2.1k" are equivalent, as are "1200000", "1200k" and "1.2M".
However subsequent display of the passband field is always in Hz.
So after entering "-2.1k, 1.2M" on the next edit the field will display "-2100, 1200000" (Hz).
Solved: needed to refresh browser (yet locking occured beforehand) to get proper pop-up
1. Frequency lock
2. Quick way to set the waterfall to consitent levels
3. A few spot frequencies
Lock is excellent thanks.
The other features could be covered by a few URL local shortcuts (in the admin interface I can append commands - waterfall levels, enable spectrum, disable DX-Labels etc.)
That is admittedly a narrow use case and having shortcuts in the locked screen require it to change frequency so maybe a "confirm" option.
I suppose the locked and unlocked "double tap" pop-up could contain slightly different things.
