40m band European extent - not showing correctly, though the region is set? [fixed in v1.440]
It would appear that the band scale is not being shown correctly for the selected region.
Clarifying:
Admin Config page has ITU Regionset to "1 - Europe/Africa".
Going to the main page, dropping down the menu for "Select Band", selecting 40m. The UI updates to the location of the 40m band as one would expect. However, the blue band scale at the top of the UI is showing 7.0 to 7.3 MHz as the 40m band, and not the 7.0 to 7.2 band that I would have expected with ITU region set to Region 1.
Taking a very quick look at the code, /root/Beagle_SDR_GPS/unix_env/kiwi.config/dist.config.js suggests that the region setting should determine what's shown to the logged-on user, but this does not appear to be updating.
Am I correct in thinking that the blue band scale should be 7.0 to 7.2 for an ITU Region 1 selection?
    edited April 2020
    Yep. Currently the ITU region setting only has effect for defining the NDB band bar and the 80/75m band overlap (which has problems of its own). It is not used for 160m (Fstart), 40/41m, 30m (Fstop) etc.
    cathalferris
