Multiple Kiwis, single GPS antenna?
Those that are running multiple Kiwis at a location and that are using a single GPS antenna, what have you found to be a good method of doing this, preferably without being overly expensive?
Is it possible in the Kiwi configuration to disable the Bias-T power on the GPS antenna connection?
If not, I know I'll have to ensure that only one of the Kiwis is providing power up the feeding coax to the GPS antenna.
The 8-way I used is no longer offered, but I have installed this 6 way at other sites: https://smile.amazon.com/gp/product/B01KCY5MBU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
No mods are required on the Kiwis
I started with the Kiwi's GPS puck on the roof into this system and that worked fine, but replaced the puck with a 45 dB gain 'bullit' GPS antenna which I bought as a precaution against the losses
The 100' RG8 measured 8 dB loss at 1500 MHz and the splitter introduces 11 dB, but the rooftop location more than compensates for those losses
It is good that I haven't needed to touch it for months, since now I can't get access until the quarantine is lifted.
The Pi4 running wsdprdaemon is on a lower shelf.
£12.05 - limit on shares probably 10+ (I've only used it for 5)
Don't judge the wallpaper, the room is my SDR/workshop.
The place is magical. Not only for the radio history and legendary noise floor but for the incomparable beauty of those 70k acres and that spectacular coastline. I lived about an hour away for 15 years. I got married out there once. I have over 100 solo hikes done at certain times of the year when the tide was especially low (> -1 foot @ sunrise/sunset). This opens up certain areas of the coastline, for a very short time, that are normally inaccessible. I still have the maps and 5 diaries crammed full of notes about those trips. Good times..
