This feature has not been tested with IPv6 or mixed IPv4/IPv6 local networks. So there is likely some debugging required.
One advantage of doing this, rather than running only mDNS, is that you can still discover a KiwiSDR whose name has been changed from "kiwisdr.local". I have had to do that when there's more than one on my network.
https://forum.kiwisdr.com/uploads/Uploader/80/0b036368a5ae7d9d9663157f17ec3b.txt
https://forum.kiwisdr.com/uploads/Uploader/be/3528b548e05f8c2abfe512a17f2424.txt
My kiwi is fully updated, has the correct switch set on the admin networking page ,and won't respond to the my.kiwisdr.com request, or to the kiwisdr.local one. It never has done. I just get a message saying No KiwiSDR(s) found for your public ip address:*******.
As far as I know, everything is set up properly. It works very well in every other feature that I have tried. It's a bundle of fun. Glad I bought it.
I.E. does the browser get to the internet through the same gateway as the Kiwi?
The MDNS/Avahi thing (kiwisdr.local) is unreliable when used from Windows. Sometimes it works, sometimes not.
I just tried this again to verify it works.
As I mentioned earlier the only registration from a Kiwi for the service using that Kiwi serial number was from the .214 ip on Feb 11.
Yes the IP address has changed again. We have been having winter storms and there have been some very short interruptions of power supply so I guess that may account for public ip address changes in the router as it is knocked over by the momentary power cuts.
The debug page shows the correct, up to date address. I am using your proxy service for access outside the local network. That works fine so the kiwi must be logging in when it reboots.
I have it set to reboot each night.
Odd to say, but the mykiwisdr.com command now works as it is supposed to. It REALLY wasn't working when I made that post.
The other one, http://kiwisdr.local:8073/admin returns a message that the site can not be reached.
I am mostly using a chrome book for access, also an android tablet and sometimes an android phone, though the only one I've tried the kiwisdr.local:8073 has only been used with the chromebook.
No big deal John. I don't waant you to go to great lengths to debug this. I'm sure you have enough to do already.
Cheers
By the way - I wrote previously about GPS difficulties caused by my weird location, sheltered from the sky. I disconnected the antenna and in a stable temperature environment, it doesn't matter at all. The thing is dead stable. I check it daily on WWV on 10 mhz and it has been dead on frequency for four days since I made the initial correction manually.
Great product.
What does it mean when I get this message? I was just using it. It's there.
Ken VE3HLS
No KiwiSDR(s) found for your public ip address: 134.xxx.xxx.xxx
Hi Ken,
I believe the message means that your router has not been configured to allow connections to the KiWi from the outside world via your ISP.
When you say you were just using it, I assume you mean just using it on your own personal local network ?
Hi Ken,
At some point did you see an entry for your Kiwi and then click the
clear entry
link? Because I see in the logs that your Kiwi registered for themy.kiwisdr.com
service back on August 2 but does not now appear in the table for some reason.Try restarting the Kiwi and see if the entry shows up.
I have people using my Kiwi on a regular basis. It's setup for outside users.
Ken
Sorry, an entry where? I can tell you I definitely haven't clicked any Clear Entry buttons.
Ken
Ken: Okay. Please email support@kiwisdr.com your public ip address and/or Kiwi serial number so I can check the database. Also, please restart your Kiwi and let's see if it re-registers correctly.
Will do John.
Just finishing breakfast here and will wander down to the shack after I scrape my teeth!
Ken
My Kiwi is configured to reboot once a day. A few users were having problems connecting and this fixed it. That said, I will manually reboot it as soon as it lets me back in.
Ken
HHmmm...I can't get back to my Admin page after several attempts. Maybe it's doing its automatic reboot now? It's 0327 UTC as I write this, within the 0000 to 0600 window my Kiwi mentions.
Will keep trying.
BTW, logging on to the Kiwi has become very slow in the last few days, taking a minute or more at times. The Kiwi connects to the router via ethernet LAN through a 4 port switch in my shack, and computers connect via wi-fi.
Ken
Finally got back in. Rebooted the Kiwi Server. Afterward, as soon as it got to the Admin page it booted me out again, to wait for another 60 seconds. This time, when I got back in I rebooted the Beagle. Just waiting for that now...
My minute is up. Something else is wrong here because I'm into my fourth minute of waiting to log back to the Admin page following the eagle reboot.
Ken
So it looks like you're using the proxy service (even though not a publicly listed Kiwi). I didn't quite realize that. It's possible that the my.kiwisdr.com mechanism doesn't work when the proxy is in use. I'd have to do some checking. [edit: it does work]
But I just got a big box of prototyping parts delivered for KiwiSDR 2. So I have to spend time on that. There are just not enough hours in the day..
That's exciting news about the KiwiSDR 2! Best of luck with that. I hope you're able to find someone who can assemble them.
No rush on the other thing. I seem to be having my own problems with my Kiwi or my network. Can't access it from here...
Ken
Not sure I understand. Are you having problems making a regular user connection from your local network? Or is it the same issue as with admin connections -- you get booted within a few minutes?
It seems I'm only getting booted from /admin sessions, and not from listening sessions. I was getting kicked off every 2 minutes or so...
Now I see what I did. Dumb mistake. In my defense, there are so many settings in there that I'm unfamiliar with most of them. I've tried to keep quiet about my Kiwi, only letting a few groups know, because I don't want any problems from hackers and other ne'er-do-wells. That's why I would have turned off that setting. I didn't understand the full repercussions of doing that.
I'll leave it on because it looks the exposure is minimal.
Thanks again,
Ken. VE3HLS
Ken is talking about the setting on the admin network tab:
(Yes/No)My.kiwisdr.com is still saying no KiwiSDRs at my public ip address. Could that be related to the reverse proxy thing? I'll check tomorrow to see if it has my correct ip address. Would that be the address of our router or the address of the Kiwi itself?
Ken VE3HLS
Yes, I didn't change it because I wanted you to see that it was really set to "No". The entry now appears on my.kiwisdr.com as it should.
When you visit my.kiwisdr.com it will show you the current ISP-assigned public IP of your router and DHCP-assigned local IP of the Kiwi. I note that the public IP is different from what you told me in email. And this is typical of ISPs where residential IPs are not static. Of course the real reason the proxy was needed was because your ISP disallows inbound connection setup (i.e. people connecting to your Kiwi directly).
