New out of box KIWI updating issue. Compiles the same files over and over again. [git fetch issue]
Just got my brand new Kiwi SDR and connected it up to the network and started it up. As expected it went into update mode, but after more than an hour it is still flashing away its blue LED and if I try to connect to the kiwi port 8073, I get a message saying that it is compiling file #1 through to #60. The query is that it is compiling these files over and over again. It has gone round several times in the now hour and 15 minutes since I turned it on.
Is this normal?
If it is stuck, is it OK to switch off and let it start again? I don't want to corrupt the file system with a hard power cycling event.
Not sure what to do next. This isn't what it says to expect in the documentation.
Just for extra info, it has a suitable power supply supplied by the seller (Martin Lynch UK) and it is connected to an antenna and gps antenna. It is connected on a network cable and the local network has good Internet access.
Thanks for any help you can give.
Tony G0BZB
Is this normal?
Tony G0BZB
I left it two hours the first time, one and a half the second and now we are on the third attempt.
Deeply puzzled - and I'm a linux neophyte so getting nowhere.
I've checked and rechecked.
It has good power, good internet connection and is properly assembled. It came assembled actually. I didn't have to do anything other than plug it in.
Hoping for a solution.... )
73s
de G0BZB - Tony
Something is not right with what you describe. The feature of displaying the compiled file number when connecting as a user was removed a while ago because it conflicts with the new way compiles are performed. So this means the update process does not have the current version (v1.376) installed on your Kiwi for some reason. It's now impossible to say what you have and this is likely why the build process is failing. A complete re-install from the sd card should fix the issue.
I logged into the admin page, and there under the Update tab, I can see the following information:
Installed version V1.2 built January 30th 2020 18.27:42.
This accords with the time I did teh re install from the card.
Below that, it says:
Update to version 1.376 in progress.
There are also options on that page which look like I can stop the Kiwi from updating. I am assuming that if those are set to prevent updating and looking for updates, when I re-boot it, it will probably come up and at least work as a radio so that I can test it out.
Hopefully, someone can help with a solution, but I certainly appreciate any help offered - so thanks. This info I just found may help you point the way forward.
Cheers.
Tony G0BZB
Maybe if the 1.2 version is incompatible with the current updating procedures / software, I should get the seller to supply a new disk with a compatible version. I might be able to download a version, but I have never created a flash disk before. I do have a usb port adaptor which might enable me to use the disk in my dashcam for this, but I'm not that happy with having to do this on a brand new shop bought item. It must have been hanging about in the seller's stock for a while.
I obviously need to do some more digging to find out definitively if that is what is wrong and it is the incompatibility between early firmware and the new update files.
ML will have no clue how to make an sd card with the current version. Such an image doesn't even exist (they take hours to construct). The network update process is the way to go.
I sent you a pm with the details - at least I hope I sent it as a pm..... or else my kiwi is wide open...
Will get back to you shortly.
My adsl connection comes in at the back of the house and that is where the router is. My radio antenna is at the front of the house and that is where my Raspberry Pi wispr decoder is currently, and where I want the Kiwi. To get around the issue of not having wire trailing through the house from front to back, I have set up a wireless bridge router beside the kiwi. It is on the same network absolutely and does dchp for the kiwi or anything connected by wire to it. The kiwi is plugged into that router. I tested it with my Raspberry Pi and it worked fine with the Pi's wifi switched off. It did its wispr spots and uploaded them to the server at wsprnet.org by the wireless bridge connection.
I don't think it can be that bridge set up. I hope not. I also tried to update the kiwi by plugging it directly into the adsl router at the back of the house and got the same results - just going round and round for an hour or more and messages saying that it was compiling the same files over and over again when I tried to login to port 8073.
I will have a go at logging into that git hub link with a wired connection from my chrome book with the wifi switched off and let you know the result
I just downloaded the zip file on both my chromebook (wireless connection direct to the adsl router) and also on an old linux netbook with a wired connection into the same wireless bridge as the kiwi is using and out to the adsl router and Internet.
This presumably rules out problems with the network link to the repository and also the question of my IP address being blacklisted.
The zip archive came down fine onto both computers, the wifi chrome book and the wired only linux netbook.
EDIT:
I checked on kiwilocal:8073 and I got no updating message so I swapped to a known good network cable.
I will wait for further instructions.
Cheers
I also noticed that the sound had vanished during the evening. I don't think it is a user error. It just went silent.
What happens when it finishes? Will it just reset and come up normal ?
blue one which I assume refers to its building activity. The lights were still flashing up until I power cycled it and they have all begun again now.
Sorry that I did not spot your remark which preceded my last message.
Sorry about all this mularchy.....
You should be able to get back in now.
