My Airband
https://sdr.hu/?q=air-band
Also in Russia.
http://air.swl.su:8073/
Please add a wideband FM.
I want to publish FM broadcasts.
Also in Russia.
Wide FM gives up.
https://github.com/simonyiszk/openwebrx/wiki
The only way to possibly do it is to add a WBFM demodulator to the FPGA so that only audio is being moved across the serial interface to the Beagle. But that also means adding passband filtering to the FPGA. And for the RX4WF4 configuration at least there is no room on the FPGA for that.
What hardware are you using to do this?
Thanks
I have been wondering if I could use something like this MixNV, to downconvert and send the airband to the KiwiSDR.
https://windfreaktech.com/product/rf-mixer-downconverter-upconverter/?_vsrefdom=adwords&gclid=CjwKCAiA35rxBRAWEiwADqB377RNNBMTepQY_ajBG2B6S43cR-cOGf_iGEQ1rrYLOOkWPSdxoD5NvhoCkr8QAvD_BwE
I think it may work...
Also, thanks for the GREAT diagram of your hardware setup. Makes perfect sense (and I wish I had the Leader LG3236)!
Thanks.
http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=107&products_id=301
https://www.minicircuits.com/WebStore/dashboard.html?model=ZAD-1+
There is a similar system in Russia.
Good luck!
That LG3236 is a signal generator right? So it can take signals and up/downconvert whatever you want on the fly?
I sure enjoy listening to Tokyo Control on your SDR. I've flown in and out of Osaka and Narita many times and have a high regard for the professional ATC people.
I created a video of a fun listening session on your KiwiSDR and the one near Moscow:
There was some intermod from two mediumwave stations, probably getting into your LNA. That doesn't seem to be serious, and a bit of RFI suppression should fix it. That server is sensitive, tunes accurately, and has the nice sync detector for listening to ATIS dx... Maybe even VOR/LOC dx, but I have not tried that.
Edited 4/2021: Link and comments about video.
