Kiwi phase/frequency stability & Ebnaut decoding
This discussion was created from comments split from: offset for vhf wspr decode.
I have also tried without success - perhaps due to incorrect post-processing of the output audio file.
http://abelian.org/ebnaut/software_linux.shtml
I haven't documented the kiwiSDR onboard GPS performance but I have examined it, particularly in comparison to use of the Kiwi with an external clock. You can do the same by comparing two of my kiwis, one with a Bodnar GPSDO which generally appears to be better than 1 ppb and to not limit the phase noise performance of the kiwi with another using the on-board GPS reference.
Bodnar referenced Kiwi
and
on-board kiwi GPS
are both looking at US NIST LOS/"groundwave" signals transmitted from less than 20 km distant.
This may not be entirely satisfactory since the on-board kiwi's GPS antenna is outdoors but not very well located.
A known problem at receiving EbNaut with the kiwi (at least on my side) is the lack of timestamps. I think kiwiclient would support timestamps, We only have to get them to the vlfrx-tools somehow. Did you compensate the buffer delay during your attempt @G0LUJ ?
There is some example code in kiwi/wavreader.py of the kiwiclient repo that shows how to extract the timestamp info from the .wav file.
