offset for vhf wspr decode
Hello,
Is it possible in VHF to modify the receive center frequency of the WSPR frames either in the extension ex 144489.400 or to be able to declare the offset more precisely eg: 115999.600 in the admin / config panel if I find 400hz of offset on my upconverter.
On the other hand it seems that autorun 2m does not work
Thank you
Thank you
I've been there before. The above advice is correct - the KiwiSDR will not provide the fineness of adjustment you require. You should correct in the downconverter if you can.
