switching mode converter <> no converter with antenna selection
Hello
Can we imagine switching from HF mode to converter mode simply by changing the antenna, because converter is an antenna for the kiwi, just frequency display is different.
73' Ren? f6bir
73' Ren? f6bir
Assume this has been implemented. When you have a Kiwi that has multiple connections, either because it is public or because it has private access by a group of individuals, what should happen to everyone else connected besides yourself when you change from an HF antenna to a V/UHF one?
Thank you for answer, the need was only for a local administrator use, to use it like a hard multi-band receiver without web connection , I understood it is a problem for public access connection, that was just an idea
Thank a lot.
73' F6BIR
