Cannot access kiwi but some slots are free??
I've had this problem before but it seemed to be fixed for a while. Sometimes I can't access my kiwi (apart from via admin) because it says all 4 available slots are used.
However, when I check via admin they aren't all being used. I've tried refreshing the browser or changing browser and waiting a while but in the short term the only way is to kick someone else off.
Sure enough, when I join there are still spare slots left!
I'd look at the connections, see if any look ripe for blocking and block the most likely range.
Some routers allow you to see "connections" so if it is not registering on the Kiwi log you may be able to see "too short to register" connections there.
Problem went away after switching VPN off...
Is it a static-IP vpn, not one that could change public endpoint?
