Cant find Kiwi (No I.P assigned)
Hello fellow Kiwi lovers
Just installed a kiwisdr at our local club station, the kiwi fires up nicely but im not sure if its getting its I.P.
A few flashing LED's at start and then they flash constantly from left to right-right to left....till the kiwi decides to shut down.
I have tried "kiwisdr.local:8073/admin" and "KiwiSDR auto-discovery scanner v1.5" also other examples (itunes bonjour .....etc) on the quickstart quide with no joy.
Green LED flashs when the ethernet is connected and yellow LED is constant. All seemS OK even changed the ethernet cable 3 times.
what am i doing wrong?
Thank you
Thank you
yes removed it and now its nice and flasahy no shut down. However, still cant get to the admin page and did the auto discovery scan too no kiwi's found
and yes i figured it had to do some updating
(this is why you should never be talking on the phone when your installing a kiwi)
the "kiwisdr.local:8073/admin" does not work, it has to be 192.168.1.128:8073 (my.kiwisdr.com)
KiwiSDR auto-discovery scanner can't find the kiwi still
http://192.168.1.128:8073/admin works
gong to start config now see how it goes
so i've setup and configured everything plus the API key and set the proxy name and emailed support.
again thanx for your help and patients jks
