Bot appears on 517 khz with rapidly changing IP address
Last night I was getting a channel camper on 517 khz (USB I think...)
When I kicked it, it would re-appear with a new IP address...
I did IP blocking for a bit but it became clear that it would keep coming up with a new IP address...
So I added a LOGIN passwd to the Kiwi and the camper-spoofer went away.
Anyone else seen this?
If the range of IP's is similar just block a wider IP range. E,G. rather than 47.88.219.24/24 do 47.88.0.0/16
If you did that every day you could eventually block a genuine user, but it would take a surprisingly long time (I have found).
Will watch logs for similar actors but I already have many IP ranges blocked at the router out of pure spite ;-p.
