S meter extension - prevent clearing? [fixed in v1.318]
The s meter extension is a great tool, I use it frequently. One thing I do is take two readings, first a baseline on a nearby "empty" frequency to get an estimate of my overall background noise level, then one on the station of interest.
When I change frequency, the graph clears, which is probably useful to many users. Is there a way to prevent this? Sometimes it would be nice to see both signals on the same graph.
Thanks for adding that it's really useful.
Having played wit it for a while I think it would be even better if it was possible to add a 'pause' button, so that you could halt the scrolling whilst you made any changes to the antenna or whatever, and then be able to restart it again from where it halted. This would permit 'side by side' comparisons without a large gap in the middle.
e.g measure noise floor, tune to signal and measure level, Pause, change antenna, restart, measure new signal level, tune back to noise floor and stop (or pause again).
You would then be able to directly compare the signal levels and respective noise floors between the two antennas under test.
Sorry, jks
>I suppose you could just drop the speed, make the change, bring it back up?
Yes I tried that but unless you remember the original speed setting you used or if you move the slider too slowly, it messes up the time scale.
Thanks for adding pause to the S-Meter, it's made it a much more useful tool.
Here is a recording of the evening hour during the opening of the 630m band, where the ground-wave QRN is replaced with sky-wave QRN.
Any chance of 15min and hour markers too ?
Thanks (again) John.
