Anyone using the DX Engineering RF-PRO-1B Active Mag Loop Antenna?
It seems that when using this antenna, local BCB stations overload and cause distortion on all freqs and the waterfall is a mess. Currently, the antenna is ground mounted on a 10 foot roof tower. Rotating around makes little difference.
I have listeners worldwide that listen to El Paso BCB. Things are much better when using a ground mounted vertical 40-10M Hustler (less gain I suppose).
I would be interested in hearing other user's comments.
73, Rick W5PIE
73, Rick W5PIE
look at jimlill.com:8073, it has 3 notches in the MWBC band as I have local TX just about 1.5 miles away. rest of band is usable
