AM mode seems now suport TDoA (??)
Hello this is my first ever mesage in this group
Two days ago i experimented with 153 kHz a station from Romania with my android tablet . Forgot to change the mode from AM into IQ but the results were very good and very fast . Just 30 seconds were enough to identtify the trasmitter site with 3 spots
I seem to remember asking John to so this some time ago, as I got fed up remembering to select I/Q each time I ran a TDoA session, but I'm not 100% sure if it got implemented.
As understood from the files produced by the kiwi spots after the TDOA analysis , inherent IQ mode is used that cant be played in standard PD players
Something other I noticed , ifyou try to use non kiwi spots , ie time signals , they immediately change the SDRs frequency to theirs > I cant still understand on how you can use them for analysis
What is important is the setting of the passband. It should be symmetrical about the carrier (what you get by default in AM or IQ mode) and no wider than the signal of interest.
When you say "non kiwi spots" what do you mean exactly? If, while the TDoA is open, you tune the Kiwi manually and then click the TDoA "submit" button it should use the manual frequency you entered. When you click on a "reference" station on the map (green label) then current frequency will be tuned to the frequency of the reference if one is defined.
If you select a time station from the "select band" menu, and then click TDoA submit, the frequency of the time station should be unchanged.
Two non kiwi sports for example as noticed in the European part of the map
I cant understand on how they are used for...
https://forum.kiwisdr.com/uploads/Uploader/37/6ab7e4e6d53074c324450e494b4267.png
https://forum.kiwisdr.com/uploads/Uploader/ff/e2afbfce231f8803f1221cff636a16.png
I made this mistake many times when i tried to DF positions of some standard AM stations on LW and MW for the time. . I m now more careful in selecting only kiwis !
There are two different kinds of markers on the map. Kiwis that can be used as sampling stations are shown in blue and change to yellow when selected to be used in a TDoA measurement. Reference stations with well-known positions are shown in green. When you click on these they are not entered in the sampling station list like Kiwis, but rather entered into the reference station box at the bottom right of the TDoA control panel. And also the Kiwi is tuned to the frequency/passband appropriate for the reference station. This is intended to make it easier to practice TDoA on a known signal.
You can disable the display of reference stations in the list to the right of the map (also select based on reference station type). And also disable display of the TDoA Kiwis. This is useful because there are so many markers on the map now.
From the yesterdays change log in github
