Can't connect to SDR using reverse proxy after using a hotspot on a smartphone [not a Kiwi problem]
Step by step what I did:
1. KiwiSDR on local UTP cable connected internet AND proxy -> PERFECT.
2. I want to get the SDR in a forest area so the noise levels will drop enormous.
3. The people where I can install the SDR use fiber internet but it's not convenient to drill about 5 holes to get the UTP cable to the SDR. The WiFi signal is too weak, a range extender in the middle is also no option because I have still to drill holes to get outside.
4. So I got this idea, I brought a data SIM only plan, use it in an old smartphone and organize a hotspot, no problem.
5. The smartphone has of course no UTP connection so I configured a range extender as UTP data transfer unit. The speed is about 10 Mbit/sec down (not interesting) and 1 Mbit/sec up (3G) in the forest. When I want I can switch to 4 G and have a quicker connection but most of the time this consumes much more data (strange but true).
6. Laptop connected to the range extender, UTP works fine to connect to internet, WiFi works fine as well.
7. Now its getting important, how to connect to the SDR!?
8. Range extender connected via UTP to the SDR, cant find server (of course because the IP is wrong for the proxy).
9. Log in kiwisdr.local:8073/admin. No way. To be 100% sure but ridiculous, connect from laptop via WiFi to the smartphone hotspot and try to get through the range extender to the SDR, no way.
10. Of course I am dropped out of the SDR.HU listing, I am invisible because not connected anymore to the proxy. Of course http://kiwisdr.local:8073/ doesnt work either.
11. What is the problem, why it is not possible to get into the SDR and re(register) to the proxy? When I have no access, I cant re(register).
12. Back to the old connection, plugged out the UTP cable from the range extender and back in the fiber modem, within a few seconds a working SDR and Admin pages. After a few minutes my link on SDR.HU was operational again.
13. Im lost right now. No options left insight my limited network knowledge.
14. Is it not possible to set up a proxy with another parameter, lets say on a unique MAC address?
15. What should I do, please HELP!!!
Best regards,
René / The Netherlands (PE0RBE)
Best regards,
I'd start by putting the laptop on the same network as the Kiwi (use a non-managed network switch after the range extender if only one port), find the kiwi on there using something like Angry IP scanner (cos it's very quick). That is assuming the bridge does more than one device. If the bridge is single device power it down then back on with nothing connected, then connect and power up the Kiwi.
The issue to me is that you don't know if the Kiwi is up and fully routed, there are a few things that could be stopping it once up but you do need to find out what condition it is in.
I'd not worry too much about finding it by name, find it by IP address then work towards the net. There are a few points where this could fail but bridges can be a bit awkward depending on what MAC they present upstream and what mode they are in.
Without knowing the extender and few more details it's hard to know at a basic level if the link should work and when it does work if other things like the laptop will be able to connect from the wireless side.
Questions:
1. what make/model is the extender (so I can look up the instructions)
2. what brand of mobile is providing the wifi
Some of us on here would love that sort of opportunity.
Just let us know how far you get and Im sure there is a solution close by.
Good luck with it.
I spent two hours today trying to setup something similar (although simpler). I have a little tp-link wr802n wifi router with an ethernet port. I tried everything but was never able to pair it with my phone (iPhone 5S) in hotspot mode. I could pair it with my regular wifi router just fine. And the laptop will pair with the phone hotspot no problem. But the 802n and phone won't pair. I tried all the 802n modes (hotspot, range extender, client). Nothing works. My everyday Kiwi uses a different model tp-link wifi range extender to overcome cabling limitations. Works great.
So I have no test environment in which to debug a possible Kiwi problem when using a wifi router/range-extender paired with a phone. But it's hard to imagine how this is any different from other range-extender setups that work. The phone is just a hotspot. Even if temperamental.
On the WR802N I'd reset it, restart the iPhone then try.
I have one in use here (client mode) on the second Kiwi (to Microtik AP) and it does need to connect to the right router MAC, I.E. I can't set it up for SSID "HomeWifi" on one AP then move it to another access point with the same SSID, that caught me out while rushing, the MAC was almost the same.
I assume the iPhone has the exact same MAC every time the HotSpot is enabled or that will cause issues.
In client mode the single client behind it should be connected after the TP-Link is powered, they can take a while to route as it seems to sometimes initially show the AP the same MAC for TP-Link and the Kiwi. My TP-Link is set to get an address by DHCP, Kiwi fixed IP btw.
Other issues I've had in the past
Localisation, region set on wireless devices before they will work
Password too complex/unsupported characters for some devices (yes in this day and age).
Did that. Many, many times.
One thing I have noticed on iPhone initial wifi setup is they are more distance sensitive than Android so I wonder if that could affect it as a hotspot.
I see the hotspot needs 8 or more characters so I'll try simple characters and only 8, just in case the TP-link is in any way similar to my cameras here they have some stupid low limit.
Bar on iPhone says item connected then not a few times, walked away for coffee and to find something to put on the lan side (someone has wiped my test laptop, well thanks...) blue bar now solid. Booted Live linux tested internet access.
So TL-WR702N to iPhone 6 hotspot works.
On the addressing I see the iPhone can give out only a few addresses (Network Range 172.20.10.0 - 172.20.10.15) so safe static useable address for a Kiwi should be something like 172.20.10.10, with gateway 172.20.10.1, broadcast 172.20.10.15.
Not sure if I can usefully try that on a Kiwi BBG without cape, might have a go when home.
If it has PNP enabled turning on the "Auto add NAT rule..." might fix that.
For manual port forward setup the Kiwi should always be on the same (internal) address each time so there may be an option for doing that in the Huawei administration interface.
Assuming you didn't use that admin interface to set it up looks like that may be on 192.168.8.1 when you are in it's wifi.
I'd be tempted to try rotating the loop to see if you can find it with the null, from your description of the location you should be able to fine tune the install.
Here I live with my loop 98% of the time nulled on one house, took me a while work out the most useful orientation.
Background noise level is much better than here, nice spot.
Your AM radio is nice and strong there too, I had no idea that sort of thing was legal.
