Labels in dx.json
Prior to the arrival of my new KiwiSDR I am compiling a dx.json for my HF aeronautical stations and taking a look at some of the entries in existing dx.json files in the repository of WA2ZKD I see some numerics such as those in this entry:
,[189.00,"AMN","RUV","Iceland",363064,0]
What does 363064,0 mean or indicate?
Also I have determined that the colours are:
WL=Red
Blank=Blue
SB=Green
XX=Purple
But what of DG and NoN? And are there any others?
Thanks,
Michael
Palmerston North, New Zealand
WL=Red
Blank=Blue
SB=Green
XX=Purple
Thanks,
Michael
The label "type" field just controls the label color as you've noted. They are assigned particular meanings but you can reuse them for any other purpose. There are some other fields. "lo" and "hi" set a custom passband. "p" starts an extension (with parameters) when the associated label is clicked. "o" is a carrier offset used for NDB signals to show where the NDB carrier is located (by showing a small yellow triangle when the label is moused-over)
