Direct Connect to Computer
So I solved the mobile power puzzle with a Lithium Ion battery and a dc/dc buck converter that seems to be pretty quiet. Now I need some help.
I love to DX while camping. Usually that means primitive camping. I want to run everything off of my battery. I have an old Acer tiny laptop I want to use. I bought a new oversized battery for it. I want to connect directly to the Kiwisdr.
I have a Hoo Too Nano wireless router. Unfortunately, it will not provide a wired connection in bridged mode. I wish the Green just had a WiFi chip, it would make things much simpler.
So, is anybody connecting directly to their PC? Have you found a wireless client that will hook to the Kiwi?
That will do wireless, a few (100M) wired ports, DHCP and just about any other feauture a (£200) router can for about £20
Obviously you could set the IP address on the BBG and Laptop to static then connect between the two with a cross over cable (straight may work haven't tried) but the hAP shortcuts so many issues and allow very fast adaptation to location changes (connect out via the WAN port).
The other common wireless bridge is the TP-Link micro router and they work well but here in the UK they are more expensive than a hAP while offering less features and options.
--Later--
To check I wasn't telling people to overload the BBG USB port I fired up one of my hAP Lites RB941-2nD and set it to CPE bridged to my home wifi, works well and according to a USB power meter peaks at 230mA. With one device (a laptop) connected the running power is about 130mA @5V.
One thing that has bitten me twice now is the amount of time the hAP will run with from the linear supply with the power tuned off. I set it up to a wireless router upstairs then took it down to the Kiwi, with Asus AP, plugged it in glanced at the power lights while booting, went upstairs to my laptop to configure it, no luck with any setting on the access point, just couldn't ping it or see it connected.
It was actually off, the power and networks lights were just running from the PSU capacitor (epic facepalm). At that point I figured I should take up gardening. I did power it up and try a couple of settings but by then the shame was beginning to burn.
