Is it possible to pass keyboard shortcuts via a URL? [fixed in v1.274]
I can't seem to find this addressed, which doesn't mean it's not there, I just can't find it.
I really like the configuration options that are available by passing arguments in the URL. I tend to bookmark configurations of interest this way. It makes comparing and sharing receivers, antennas and systems easy. Because I often use the Kiwi as a measurement device more than as a communications receiver I often set a bookmark that brings up a receiver, mutes audio, turns on the spectrum display and possibly brings up an an extension such as antenna_switch. At that point I may still be left with some setting which isn't quite 'standard', that is I find I have to use keyboard shortcuts, e.g. 'shift-ctrl-Z', 'S' 'yyy' and 'x' to clear away the DX labels and console so that I can see an autoranged full span spectrogram and waterfall without other stuff in the way. Perhaps I'm too used to spectrum analyzers but I find this useful. At the moment, however, I don't know how to pass keyboard shortcuts via the URL so I have to do this manually every time. Am I missing a method of passing keystrokes via URL or is it not possible?
I was going to test it then remembered I dislike add-ons that have that much access.
I'm still figuring out what I want but something like:
http://n6gn.no-ip.org:8073/?mute&sp&f=14100/1000z0usb&wfm=-120,-20&keys=yyyx
gets one a fully visible full spectrum display with a 14.1 MHz USB 1 kHz BW noise measurement included (subtract 30 dB from S-meter reading to get noise floor referenced to a 1 Hertz bandwidth) while
http://n6gn.no-ip.org:8075/?mute&sp&f=28000/1000z0usb&ext=ant_switch&keys=yyy&wfm=-120,-20
brings up a similar measurement but has you ready to switch among antennas for comparisons. ( I haven't figured out how to pass the particular antenna choice in yet, ext=ant_switch,1 or ant_switch,antenna1 don't seem to do it)
This is great and very useful, thanks so much!
Also good for phone use if bookmarked to common test states.
I emailed Kari in August last year to ask about this as a possible enhancement, and also maybe allowing up to ten antennas to be switched, but unfortunately I didn't hear anything back.
Remember that the extension name in the "ext=" only has to be unique and is not case sensitive. So you can get away with typing just "ant" instead of the full extension name "ant_switch".
Thanks,
Is it possible to add any defined url switches / extensions that were present if the browser session was opened with them, to the green 'copy to clipboard' button in addition to the standard frequency and mode etc. ?
Or maybe all the current parameters need to be added, so that the config can be fully replicated from the url string ?
Otherwise they have to be manually added if you wish to send a pre-configured URL or store it as a browser bookmark.
Thanks,
Not as exact as a green shortcut with everything but a quick way to alter the interface, bandwidth etc. to a prefered mode/layout (or five?).
