Specify which receiver number to use? [fixed in v1.272]
Is there a way to specify which receiver number to use, say as part of the URL, and if not could one be added? Sometimes I would like to use RX3, which I have password protected, locally, to keep all the other receivers open for remote users.
Mike
From the CHANGE_LOG file: More information about URL parameters: http://kiwisdr.com/quickstart/index.html#id-user-tune
kiwiclient.py needs to be modified to take advantage of this change.
TNX & 73 Jari
I'll tell you what worked not what should work, I'm not bright enough for that...
If you want me to test (and don't have others using it) set a temporary password and I'll give it a go.
Maybe the & wasn't the fix the third attempt was.
Also, you are correct about '?' and '&' in URLs. But '?&' works, probably because the '&' is ignored. If you actually wanted to use an '&' in your URL parameter it would have to be escaped.
