WSPR, who is running it?
Are you running wspr? If so, how.... the extension, the AI6VN code, an external app? What is your reporter Callsign?
I run Rob's code on 2 kiwis and do 14 bands as WA2ZKD
Thanks
Per his comments I gather that several of us are running v 2.2d which includes support for merged receivers.
Mike N8OOU
http://mardie4.100webspace.net/wspr/day27/top_wspr_spotters_by_number_of_spots_day27.txt
I have some similar data I gather and here is KD2OM's results for yesterday, 27 Feb. Steve (2OM) is typically in the top 3 worldwide and #1 in North America almost daily for the last month or so. He does it with 2 KiwiSDR dedicated to wspr. Each kiwi has it's own antenna system, appropriate for the bands it covers.
73 HB9TMC
I've seen sometimes on the status page that I've spotted WSPR on 10m, but nothing shows in the wsprnet.org database. Anyone else notice some of their WSPR spots don't seem to make it?
73, VR2BG.
How often it happens, how many spots don't make it, if it happens on other bands, or if there is any pattern to it happening I can't say as the wsprnet.org database files are too big for what I've got to play with them & I haven't had the spare time to figure out a way around that.
But I can say it definitely happens (yeah, I know - that's a lot of help ;^).
73, VR2BG.
Southwest UK WEB SDR reporting as G8JNJ/2 and Kernow reporting as G8JNJ/3
Using these frequencies
137.50 kHz
475.70 kHz
1838.10 kHz
3570.10 kHz
3594.10 kHz
28126.10 kHz
Using the callsign "ka7oei-1" with the AI6VN "wsprdaemon" scripting, we have active 24/7 WSPR sessions on 2200, 630, 160, 80 (2 sessions), 60 (2 sessions), 40, 30, 20, 17, 15, 12 and 10 meters. At some point I'm reconsidering running only one session on 80 meters (dropping the deprecated frequency) and dropping at least one of the 60 meter channels. The processing for these "receivers" is done by an on-site machine (one of the on-site WebSDR servers - #3, actually) which is a box running Ubuntu. FWIW, it takes about 15-20 seconds for WSPRD running on this machine (quad core, 3 gig) to crunch and post the results from all receivers.
We were running WSPR on the Kiwis themselves for quite a while (fewer bands) but found the performance of the outboard processing to be better (many spots were being missed on the "busy" bands because of too little time available between cycles for the Kiwi to complete) and it negatively impacted the experience of the users - particularly if we tried to run more than 2 WSPR channels or so - causing the waterfall to slow considerably and make the Web-based UI seem "sluggish".
At the Northern Utah WebSDR site (ka7oei-1 on WSPRNET) we have three KiwiSDRs: #'s 1 and 2 each have 6 wsprdaemon sockets and #3 has just 2.
While #1 will immediately acquire GPS signals when restarted, #2 almost never does - at least until I kill the wsprdaemon sockets and restart them.
Questions:
- Why might #1 reliably acquire, despite the 6 wsprdaemon sockets, but #2 does not.
- I've considered modifying the wsprdaemon script to stop for twice a day so that any KiwiSDRs that had rebooted can get a chance to re-acquire GPS: What might be the best way to do this?
- Any other suggestions on how to work around this?
Thanks,
Clint
KA7OEI
I also do wspr tx with a hundred milliwatts on 20 meters at a different location so as not to kill the kiwi's front end under my callsign G0BZB.
