Quick comparison between the PA0RDT Mini-Whip and The RA0SMS Mini-Whip
I was recently lent a RA0SMS mini-whip to try out. Earlier this year I purchased new original Mini-whip from PA0RDT. I have used a homebrew copy of the mini-whip I built a few years ago as well. The new one uses an isolation transformer in the receiver interface as does the RA0SMS antenna. I installed each one in succession near where my CliftonLabs whip antenna is, about 5 feet off the ground strung from a plant hanger 80 feet from the house and more from the road. I have a wideband rf choke designed by CliftonLabs on the feedline about 3 feet from the antenna.
The RA0SMS antenna seems to have a lot more gain than the PA0RDT antenna. It really brings up the noise, anything above 20 MHz is unusable in my installation. As I have mentioned previously the noise floor of my KiwiSDR rises above 20 anyway. They both receive well, especially considering their size and ease of installation. Both receive WWVB with the RA0SMS doing a bit better.
I have attached a spectrum image of each antenna, the capture were about 10 minutes apart in the morning here in upstate New York.
Steve KD2OM
https://forum.kiwisdr.com/uploads/Uploader/33/88cac2c1d652c9bbff7de0d0a8346f.jpg
https://forum.kiwisdr.com/uploads/Uploader/d4/fb2ba67abcd036947383c0c8b22919.jpg
Steve KD2OM
I agree. I think part of the problem is that the antennas are only a few feet off the ground and I believe both use the feedline as part of the antenna. The feedline to a multi-section choke is only three or four feet long. I believe the comparison is valid between the two antennas but not if you compare them to properly installed versions.
My antenna switch, the way I had it installed caused some noise at some frequencies, so it is not connected, hence no switching. I am in process of fixing it so that I can switch receive antennas again. If the weather ever gets better here in upstate NY I will install the PA0RDT antenna up about 25 feet in the clear with no choke in line., it should perform fine then.
Overall I still prefer the LF enhanced Wellbrook loop as a receive antenna below 10 MHz. I have listened to your receiver before, it is very good, I will give it a try again.
73
Steve KD2OM
PS: You have a really RFI quiet site as well.
Ta Dave
M0TAZ
"That diagram there - the chokes are "as needed" right? Or do you need 2 for sure? Those brown lines above the "ground" symbol. What are they? Thinking of how I could ground coax without making another cut."
Yes the 'chokes are as needed' you will reach a point where adding more makes little or no difference.
The brown lines were meant to indicate the noise level being carried on the outer of the coax screen gradually diminishing as it gets closer to the actual antenna.
The three stepped horizontal bar symbols are ground connections and meant to indicate the addition of earth rod's, which like the chokes are "as needed".
You can ground coax by carefully stripping back the outer insulation and tightly wrapping some wire around the screen (if it is copper and you can very quickly solder with a hot iron even better) then tightly wrap the connection with some self amalgamating tape and cover with normal PVC insulation tape for a water and UV resistant joint.
I hope that now makes a bit more sense.
With ferrite cores the affect is square of the turns through the ferrite so if you can get 6 turns then that is a pretty good level of impedance to common mode signals, reverse the direction half way if you can.
We are seeking to impede the unwanted mode so it's a trade off between required affect and physical build, there is also an advantage to keeping the input coax away from the clean output so 6 turns where there is separation is probably better than 8 where IN is touching OUT, if it requires more impedance add more cores rather than bunch the turns.
E.G.
http://www.df9cy.de/tech-mat/cy40mnoisered/cy40mnr.htm
Here there is a lot of VHF about so even some air-coiled loops helped.
http://karinya.net/g3txq/chokes/
as shown in the bottom portion of the figure.
Like the situation so nicely described by G3TXQ's graphic, suitable cores need to be used, possibly several of them to cover the broad frequency range of the Kiwi. By winding equal turns in the same direction with each line on a single core, the effective current that can flow through the receiver is reduced by the "transformer action" of the cores. Current that would otherwise flow into and through the SDR creates common flux within the core that causes an opposite current to come out, thus pushing total current toward zero and effectively creating a much higher impedance than can be the case when each line has only a dedicated core.
From my experience, CM currents through the entire KiwiSDR structure produce IZ drop that appears across the effective ADC input, which is a complex function of PCB layout and conductivities - the "attenuator problem". For this reason, I believe, treating all lines as common mode lines, in addition of course to also eliminating differential noise across pairs of individual conductors of those lines, e.g. power line or inter-pair CAT5 noise, can be very effective in improving the KiwiSDR noise floor.
