A good GPS tip
placing the included GPS module with the Kiwi kit on a 12x12 piece of magnetic sheet metal significantly increases the sensitivity of the GPS module.
additionally, slightly tilting it away from the north/south poles of the earth that you are close to also helps.
thought i would pass this on to those who may not know this already.
someone residing close to the equator should not have this issue though.
>placing the included GPS module with the Kiwi kit on a 12x12 piece of magnetic sheet metal significantly increases the sensitivity of the >GPS module.
I recently repaired a GPS 'Mushroom' antenna.
It used the same basic 'Puck' antenna with pre-amplifier that is inside the supplied GPS module.
The only difference was that it was mounted in the middle of a circular metal ground plane plate approximately 10cm in diameter, which is roughly 1/4 wavelength radius at the GPS L1 frequency of 1575.42MHz.
The included GPS antenna has a magnet on it's base which suggests that it is intended for use on a vehicle roof, which would provide a suitable ground plane. So it makes sense that placing it on a tin lid or similar conductive material, with a diameter of 10cm or more would improve the performance.
