Frequency accuracy expectations with V1.249
At KPH I have been testing the frequency accuracy of v1.249 by tuning the 7 Kiwis at KPH to 20M WSPR and extracting the spots for K6PZB who transmits a groundwave GPSDO signal at 14.0970900. I have confirmed PZB's frequency accuracy at two other receive sites with non-Kiwi GPSDO receivers. All seven Kiwis report GPS tracking of 10-12 satellites and they are all set to not auto update Kiwi SW during the test run.
Extracting the 1170 .1 Hz resolution PZB spots recorded during the last 25 hours from the KPH ALL_WSPR.TXT files, I get a range of frequency values from 14097088.4 Hz to 14097093.0 Hz. I exclude from this measurement three -20 dB sideband spots with drift values > 0 which are almost certainly airplane reflections.
These 1170 spots are reported by the Kiwis in a range of -2.6 Hz to +3.0 Hz. Is this accuracy and stability consistent with what one would expect from the new Kalman filter? It is certainly excellent and great for WSPR, but some ionospheric research groups are looking for .001 hertz accuracy where it seems an external GPSDO like the Bodnar will be needed.
pi@Pi-KPH84:~ $ pzb
Total spots: 1170
Start time: 181212:1526
End time: 181213:1820
Low freq: 14.0970884
High freq: 14.0970930
pi@Pi-KPH84:~ $
pi@Pi-KPH84:~ $ pzb
Total spots: 1170
pi@Pi-KPH84:~ $
But with the recent Kalman code additions jitter seems to be worse, even with the filter turned off. The second and third images below are the same IQ measurement with Kalman on and off. You can see the Kalman filter on-vs-off is improving the situation but the base-level jitter is worse than v1.234 it seems (the absolute phase rotation in these images is arbitrary of course).
I also measured Kalman-on with two additional Kiwi connections running the WSPR extension and the IQ result is the same. So in theory there are no issues with the Beagle being heavily loaded.
This could also be some pre-Kalman problem that was introduced. I need to do some regression testing on earlier versions.
v1.234
v1.249 Kalman ON
v1.249 Kalman OFF
https://forum.kiwisdr.com/uploads/Uploader/23/669dbb2c23c0a73227652aec5a6971.png
https://forum.kiwisdr.com/uploads/Uploader/9b/168ab7d7e6fd6d35c9bff29206e172.png
https://forum.kiwisdr.com/uploads/Uploader/9b/fa10db25992d19bf108827ab267924.png
3 minute IQ display extension exposures: v1.245 before Kalman changes, v1.249 Kalman off, v1.249 Kalman on
https://forum.kiwisdr.com/uploads/Uploader/0d/1a6e42f62c741aa53374d1227c9961.png
https://forum.kiwisdr.com/uploads/Uploader/8f/0f120479cdc0643bdd05ece5919cae.png
https://forum.kiwisdr.com/uploads/Uploader/e5/4a2e43aa3ea192681a4099630b9f1f.png
https://forum.kiwisdr.com/uploads/Uploader/19/5de406cb75738786625cb620134902.png
Reason for asking, I know the Kiwi frequency is very stable, can I then reference that known clock to use while checking calibration on a vhf device? (without connecting anything directly to the Kiwi)
Sorry I should just try but don't want to spend ages looking for something that may not exist or be controlled by the GPS reference.
Click the "stats" tab on a regular connection and it will tell you the measured ADC clock down to 1 Hz (e.g. "ADC clock: 66.665913") But that number will wander particularly with ambient temperature changes. But this is different than the XO (which is marked 66.6666 MHz on the package) being held to exactly that frequency by a hardware PLL.
All to no avail. I think most are pretty clean and RF quiet. (I'd wondered about that in the days of 'no GPS devices on airplanes' )
Ah so I have to use something like an SI570 VFO (I have at least one lying about) to create a signal then use the Kiwi audio feedback to move the frequency to zero beat...
If only I had the time, capabilities and inclination. Might just have to buy one of the Leo Bodnar things.
Last thought, there is a CAT control thing for web SDR's maybe I could use that to control the signal...mm easier than trying to write my own extension and cheaper than a built clock.
Glenn, I have sniffed normal oscillators in common things that I swear could be used as bugs, they responded to vibration so with the right processing I bet could return voices, makes me think of "The Thing" from the 40's.
As a reference, the Bodnar GPSDO Kiwi N6GN/K2 which is line of sight to 25 MHz WWVH takes over 600 seconds for the IQ point to describe 1/4 of a circle, so that Kiwi clock is accurate to better than 1/(4* 600 * 25e6) = 16.6e-12, which correlates well with the Bodnar's specifications.
In contrast, the N6GN/K Kiwi which uses the internal GPS signal will describe a circle (drift 1 hz) in 10 seconds or less:
But I imagine only doppler shift measurements of the ionospheric movements would require the Bodnar's accuracy and stability. It is a credit to John's design that the external clock source is so easy to utilize in those few applications where it is required.
https://forum.kiwisdr.com/uploads/Uploader/e6/6d58175c19e8a6818c0ca7faa5eaf6.jpg
https://forum.kiwisdr.com/uploads/Uploader/a5/4e69ab42ed7680ae145c0517046855.jpg
