Kiwi not coming up after update (remote site) [fixed with software reload, root cause unknown]
Hello. Today I lost contact with my Kiwi-receiver. I connect to it with 4G net. (70Km from where I live)
I did an update from .44 to .45: Normally I had no such problem after update.
I have a remote system for switching the Kiwi's powersupply off/on. I tried that several times. It never comes online now.
What can I do with this? (When I visit my site.)
They do warn against having any voltages on BeagleBone pins before the supply, I wonder what voltages (if any) are induced by the cape, antennas, leads and network before the power is applied.
After posting that it occurred to what may be needed is disconnecting the negative and positive rails from the BBG fully to reset, not just the cycling 5V supply.
I wonder if the induced voltages from atmospheric antennas hold the BBG in a locked condition against station ground/ supply 0V and just bringing up the supply rail does not clear it?
We had a similar issue where I used to work, with a product in a test rig that required a quick button press to turn it on a few seconds after the power had been applied and had stabilised. Several solutions were proposed involving external microcontrollers, but in the end a simple 4000 series CMOS RC timing circuit with associated diode logic driving an opto isolator did the trick quite nicely.
Similarly to yours, in my setup I have an external watchdog device that pings KiwiSDR every five minutes and if there is no reply (several consecutive replies) to that, the relay breaks +5V wire to the Kiwi barrel power connector for 15 seconds, then sets it back.
Also, I'm going to connect the BeagleBone serial console to some external device that can be accessed over an uplink. By looking at serial console output you can see what's going on during the BeagleBone boot procedure.
I don't know what those levels are or whether they are big enough, but I thought that making a stiffer supply might help. It might not. We probably need to understand this environment better. The problem is clearly a common one.
On first inspection this seems to be associated with the RF filter on the DC input of the KiWi board, which is causing a voltage drop to occur (before it is passed to the Beagle) when the KiWi is drawing it's approx 600mA average running current.
Further experimentation is required to find the optimum input voltage in order to ensure a clean start up.
I'd suggest checking the DC volts on the Beagle header when it's up and running, to see what's actually being applied to the board.
Please note: This overvoltage test was done by a certified idiot, please do not attempt to reproduce the results at home.
